Question about Garden
Way too much oil to the chain - Garden
  • 92 Answers
I beleave there is a adjusting screw close to the chain bar which allow you to control the oil flow
Posted on May 21, 2011
How do i adjust the chain oil flow rate
to test if your oiler is functional remove bar and chain and start unit. if it drips oil with bar and chain off then clean the oil hole in the bar. if plugged it will prevent oil from reaching bar for lubrication of chain
Sep 16, 2014 | Garden
What chain oil in RM1015P
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
Jul 14, 2014 | Remington 10" Model Rm-1015p Electric Pole...
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
I have a Remington 16"
most any bar and chain oil for chain saws will work. The cheaper the better just make sure you keep the chain oiled up. if you can touch the chain and oil oil does'nt get on you you not using enoght and put oil right on the chain. certainly when you put the saw away to store it. even wrapping the bar and chain in a rag with oil in it is a good idea as it'll be ready for next time.
Jan 31, 2011 | Remington 16" Electric Chain Saw Assembled...
I have an Remington 3.25 (Peak Hp) 16"/40, 6 cm electric chain saw, And I have just a few questions 1.) Does it take oil/gas or just oil and if so what kind. 2.) How would I tighten the chain, its...
It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
Jan 21, 2011 | Remington 16" Electric Chain Saw Assembled...
In addition to the gas and oil mixture there is a place for just oil....what do I need to put in there ?
That's for the bar&chain oil. It dribbles onto the chain as the saw runs, lubricating the where the chain slides over the slot in the edge of the bar. Without this oil the chain & bar will overheat pretty quickly, ruining both the bar and the chain.
Good luck
Nov 22, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain will not stay oiled
Remove the bar and chain and clean the side of the engine where the bar fits. There is an oil port there that should ooze oil out when the engine is running fairly fast. If it does, then clean the drive end of the bar (large oil holes out to the chain groove on each side. Also clean the entire groove and oil the sprocket on the outer end (if equipped). If oil did not ooze out of the port, the oil pump, oil filter, and any intervening lines should be inspected. Once you have oil proceeding from the port, reassemble the bar and chain. Check for proper oiling by running the outer tip of the bar (at speed) near to a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Hope this helps!
May 31, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
16" Electric Chain Saw: what kind of oil is used for electric chain saw...
I assume you are asking about the oil for the chain. Any good quality "Bar and Chain Oil" will do fine. Do not use motor oil you use in your car engine as it will not properly lube the chain and will result in quicker dulling and early demise of the chain.
You can get the "Bar and Chain Oil" at most hardware stores or Farm Supply stores.
May 17, 2010 | Remington 16" Electric Chain Saw
What kind of oil goes in the bar oil hole?
Use CHAIN oil. Any oil will do but chain oil is thicker and sticky and will stay on the chain much longer. The price is much the same. Stephen.
Apr 23, 2010 | Homelite ZR10926 16 Chain Saw
What type of oil is used in electric chiansaw
The oil to use for the chain is called BAR OIL and if there is anything that might be universal, it is BAR OIL. You can use BAR OIL on electric and non electric saws alike. Self sharpening and non-self shaprening chains. Any manufacturer. It is BAR OIL.
Do not use any other kind of oil in your saw. BAR OIL is particularly sticky and hangs on to the chain even while cutting the wood at high speed.
Thank you for posting your question at FixYa.com
Please remember to vote
a
Nov 11, 2009 | Remington 16" Electric Chain Saw
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
