Question about Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range
HDS25 dual fuel Bosch range - for no apparant reason control panel began rapidly blinking & beeping. Had to turn off circuit breaker to make it stop. Turned on again & got "electrical 163" which quickly disappeared & all apppears ok. What's up?
fridgetech
  • 473 Answers
SOURCE: door glass stained between the two panels
The door will have to be taken apart to get to the inside of the glass for cleaning.  Unfortunately, warranty will not cover this.
Posted on Oct 16, 2007
  • 49 Answers
SOURCE: Our Bosch dishwasher will not turn on. It appears
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
Posted on Aug 20, 2009
  • 136 Answers
SOURCE: Bosch Dishwasher SHE6AF06UC won't turn on
use a voltage tester to check your incomeing volts and amp`s
Posted on Oct 07, 2009
Testimonial: "Fixed!!! No voltage at dishwasher end of cord. Same dishwasher cord plugged into different outlet worked. Don't understand but thank you, thank you!!!"
SOURCE: Bosch Dishwasher will not power on
I have a bosch dishwasher model 2046. When you try start the cycle you hear the timer inside start to activate but the cycle doesn't start. The light in the start switch does not come on as well but I think it may be burned out. We have checked the breaker and I seems to have power.
Gerald
Posted on Oct 31, 2009
SOURCE: Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Posted on Mar 06, 2010
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
After a power outage. All the lights on the range are blinking/flashing, how do I turn them off? Everything still works. Just can't turn off lights.
Hey Scott, I understand that you are having problems with your Electrolux Dual-fuel Range. When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 18, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
How do I clean the control panel on my Bosch range without activating oven settings?
Turn off the circuit breaker to the oven before cleaning the control panel.
Dec 24, 2014 | Bosch HGS5052U Gas Kitchen Range
How do I reset Electrolux E48DF76EPS?
Only way to truly shut it down and bring it back up is a power reset from the household circuit breaker for about 10 minutes. Then retry.
Aug 05, 2012 | Electrolux E48DF76EPS Dual Fuel Range
Gas top works-- all electrical is gone-- no ovens, no display panel
Try to find your circuit breaker box and see if any of the circuit breakers are tripped. If one is, push it to OFF then back to ON. If none are tripped and you know which double circuit breaker controls the oven, turn it OFF then back ON. If you know how to use a multimeter, check that you have 240 volts to the range outlet.
Dec 10, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Jul 17, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Dacor ERDS30 clock and display OK, all bake buttons non responsiv
Most likely the interuption of power is what caused the problem. try shutting down the circuit breaker that controls the range for 30 minutes then turn it back on if this does not reset the electronics. You may need to replace the keypanel and /or electronic control as either or both may have been damaged by the power surge.
Dec 31, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Error code
Try unplugging or turning off the breaker for 30 mins then plug it back in and see if you still have the 160. I'm surprised that it doesn't have an F anywhere in the code. How old is the oven. Could some of the lights on the control be out. they are LED's and sometime they do burn out. I'm thinking this could be an F06 code which could mean anything from a power surge (clock) and needs to be reset (like I said by switching of the breakers or unplugging) to an EOC (Electronic Oven Control) failure. By switching off the oven and waiting about 30 mins. if it doesn't come back on it will be the EOC. make sure the LED (light emitting diodes) aren't out on the control making you
Dec 20, 2007 | Bosch HDI7282 Dual Fuel (Electric and Gas)...
Oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Dec 19, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Bosch HDI7282 Dual Fuel (Electric and Gas) Kitchen Range Logo
70 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
