Question about Hotpoint Ultima WF860 Front Load Washer
Loud scraping sound washer stopped then flashed F-04
  • 8,197 Answers
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Posted on May 21, 2011
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I have a GE Clothes Washer WBSR3140G2ww when the washer machine starts it agitation there is a loud scraping sound to the left side of the machine. What are the possible problems associated with this...
I have the exact same unit in a 2nd home we just purchased and when the repair guy came, he said "it was in perfect working condition". Mine also has next to no agitation, I think a goldfish swimming around in a bowl makes more motion. I absolutely hate this washer and will replace it asap.
Nov 02, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer noise
Hello, If its making a loud squeeking/scraping noise, in my maytag that i repaired, the problem was the waterpump. If you turn the washer on it's side, you will see that it has a belt with three pully's on the bottom. One pulley is connected to the waterpump and right where the pulley meets the metal plate it's connected to, there should be a gold2_bing.gif coupling. This coupling sometimes comes loose and scrapes the metal plate on spin cycle (when the pulley is spinning) which causes the scraping/squeeking sound. If this is the case, you will see where the coupling has scraped a groove into the metal plate. The coupling will eventually catch while spinning and break entirely. The cheapest new water pump is $80.
Thanks
May 19, 2010 | Washing Machines
04 elantra scraping sound
that is the sound of the brake pads minimum low warning clips,wich means u are due for new frt brakes.
Sep 25, 2009 | 2004 Hyundai Elantra
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes loud scraping sound
Could very well be the pump as well. These pumps have been notoriously bad for the pully shaft housing slipping down and hitting the pump pully. More that likely your problem.
Jul 31, 2008 | Maytag Performa PAV2200
Crosley CAWC529JQ1 top load washer sounds like a cement mixer!
sounds lik the main bearings are faulty and needs a strip down to replace parts otherwise another machine may be in order
Nov 21, 2007 | Crosley CAWC529JQ Top Load Washer
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
