I have a HP deskjet D1560 with a paper jam. There's about 10 papers stuck at teh same time.
  • 496 Answers
Turn off the printers. Open the hatches of the printer and carefully and gently pull out the papers one by one. Restart the printer and the attached computer (if any).This should work out.
Posted on May 21, 2011
My printer HP Deskjet 1051 says there is a paper jam but no paper jam present
Use a flashlight to examine as much of the paper path as you can see. There may be a shred of paper left over from an earlier jam. There might be some foreign object such as a paper clip stuck inside.
Sep 14, 2012 | HP Deskjet 1051 All-in-One Printer
My hp deskjet printer light is blinking wat to do
make sure there is no paper jam inside and all the catridegwes are proper and not dry.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 31, 2010 | HP Deskjet D1560 InkJet Printer
Hp deskjet d1560 printer light flashing
After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.
Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Deskjet+D1560+Printer&product=3374275&tmp_qt=power+light+flashing&lc=en&dlc=en&cc=us
Aug 06, 2010 | HP D1560 Deskjet Printer InkJet
Paper jam appears at the screen. eventhough it's already been cleared.
try to restart you pc, and turn off your printer try to feed paper manually by turning the roller to guide paper and check for possible obstruction and check also hook type key for feed sensor if free to move. turn of printer and make test print.
Mar 23, 2010 | HP D1560 Deskjet Printer InkJet
Cartridge can't move. possible paper jam. what must I do?
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 08, 2010 | HP D1560 Deskjet Printer InkJet
Paper jamming problems with HP DeskJet F380 All-In-One Printer . The paper feeds into the paper feeder but then it seems to get off line and the paper get stuck and actually tears in the feeder. The...
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Thanks
Newton
Aug 29, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet 3940 (Paper Jam)
I have a HP Deskjet 3940 printer. And similarly to this problem here I had a paper jam that would not clear, despite removing all the paper that was stuck in it, and following all 4 steps stated on the HP website. Such as taking the back cover off and blowing dust away and turning it off and on, etc.
None of these steps worked for me and consequently I couldnt get any new jobs to print - kept saying 'paper jam'. I was about to head down the shop to buy a new printer when i tried one last thing, which HAS fixed the problem!
I put in a large stack of paper onto the feeder. and then pushed it forcefully in and out repeatedly. To my amazement this has solved the paper jam. As a very last resort, might be worth trying this?
Jul 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
jasbo
jasbo
