RISO RP3700 INSTALL PRINT CYLINDER D01-547 - Office Equipment & Supplies
2 Suggested Answers
nonontech
  • 4737 Answers
SOURCE: ERROR CODE T98-526 ON MY
Please check the Drum and it's contacts. You can clean the contacts with a cotton bud dampen with alcohol or spirit or acetone. This is usually a bad drum connector. There's nothing much you can do, but you can try another tip, turn off the machine, leave it off for few minutes and again Turn back On while you hold down the Reset button.
If this doesn't helpful, try with another drum (maybe with the old one, but working). Also clean the contact on the machine.
In case the problem persists, you better contact Riso (click here : for u.s)
More details here (click here)
Good luck.
Thanks for using FixYa.
Posted on Sep 29, 2010
Riso RP3700 with error code T03-502. Looked it up online and it said Motor clamp locked. How to fix it?
T03-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method: Jam reset or switch on power again
Feb 18, 2017 | Office Equipment & Supplies
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
My rp 3700 keeps jamming. It is accepting too many pieces of paper. not sure what to do
Risographs being high speed printers have the separation rollers which if dirty will pull more papers in. Clean the rollers well . Isopropyl helps.
Nov 20, 2014 | RISOGRAPH RP3700/3790 - 2-HI DENSITY BLACK...
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
I have a Riso RP3700 that we have been running NCR paper on. But the pass few months I have been getting jams after a few runs of the NCR it is always the pink copy that get jam on the drum. Can someone...
All you have to do is to ensure the image is pushed down the page. Either on your graphics software or on the RP3700 itself and by using the image offset function. Try 2mm at first.
If the image is too close to the margin the paper has trouble releasing from the drum as the ink makes it stick to drum. The little hook cant then get under the paper hence jam.
I am confident this will work.
Feb 21, 2011 | Riso Office Equipment & Supplies
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
288 people viewed this question
jasbo
jasbo
