Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the A/C and check the compressor.Make sure that the thermostat was set to normal mode. If there is no cooling then we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
So try this test from the outside and make your observations so that we come to the solution.
