Question about Cobra HH 38 WX 40-Channels Handheld CB Radio
I have spotty reception on a handheld CB and was wondering if there is a testing procedure I can use to check the antenna and radio. I have a multimeter. It's a radio shack handheld with weather bands and the antenna is a "rubber ducky" type
  • Anonymous Mar 16, 2014
    What is the Radio Shack TRS number for the 21-1679 handheld transceiver and who made it for them ?
    Novelist:
  • 146 Answers
The antenna is your problem not much gain. Height is everything tx and rx. Although it would not compare to a conventional cb size negates performance. Seeing is believing in this case hearing get adapter to connect to standard coax of antenna. (PL259) to BNC Coax Adapter Radio Shack sells them. And dont ask or buy any radios there. They are hardly the radioshack of choice anymore.
  • If you put 4 watts into a four-foot antenna, you will get the same power out of that antenna as if you were putting 2 watts into a 102-inch whip.
  • If you put 4 watts into a 3-foot antenna you will get the same power out as if you were putting about 1.5 watts into a 102-inch whip.
  • If you put 4 watts into a 7.5 inch antenna on a hand held CB, it would put out as much power as a third of a watt into a 102-whip.
  • If you put 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
  • If you put 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
  • If you put 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5 antenna.
Posted on Jul 08, 2011
Poor reception
There are many causes for poor reception on a cb radio one cause may be poor or poorly assembled antenna, a good antenna should be of highest gain and put up as high as possible ,An omnidirectional antenna or Ground plane will hear moderately well
in all directions but a directional antenna or Yagi will hear great only in the direction it is turned you will certainly have to decide what you or your homeowners association will allow.
Also and finally The sun is a major factor in communications Propagation sometimes no mater what your setup the reception is terrible.
Feb 24, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Handheld Radio Shack CB radio TRC-230 I can hear people but no one can hear me
First, lets make sure that the unit does transmit. Get a power meter and see how much power it transmits. If no power is being radiated, you need to have a technician check out the unit.
If you have power then pick a less crowded time to test out if anyone can hear you. Other people with more powerful equipments can only be a problem when you are transmitting on the same channel and both of you happen to transmit at the same time all the time. Chances are remote that this is your problem. Good luck. es
Mar 23, 2013 | Radio Communications
What antenna for what cb
bad ground/bad swr/any antenna will work on any CB radio as long as its an antenna for the CB range.
Oct 11, 2012 | Radio Shack Powered ON TRC-444 40- Channel...
Rci6300f reception fine hardly any output just had radio tuned
If radio checked good it is either a bad antenna or a short on the coax from it to the radio.
Apr 14, 2012 | Ranger RCI-6300F-25 CB Radio
My cb will transmit ok but my reception range is not very far and I have a K40 trucker antenna
location of the antenna is every thing.the other thing to check is you swr.If your swr is to high your reception will be poor
Feb 20, 2011 | Cobra 29 LTD CB Radio
There is no static on the gain knob and no light on ant. i can barely p/u any reception and lose reception quickly.
First try getting a good antenna. I don't know what you have BUT STAY AWAY FROM "RUBBER DUCKY" ANTENNA'S!!!
Check your SWR's!
Make sure the RF Gain is maxed
Make sure the SQUELCH is all the way to the left
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
Dec 27, 2010 | Cobra 29 LTD CB Radio
2 Shack handheld cb's plugged into car have only 50 feet reception on any channel.thank you for any reply .
Using inside a car you simply MUST have an external antenna. Even an inductively coupled one would help.
Mar 14, 2010 | Radio Communications
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
Maxon model 27SP Handheld 40 channel CB
well it appears to have a BNC connector, so that shouldn't be hard at all.
Jun 05, 2008 | Maxon HCB-10 40-Channels Handheld CB Radio
Cobra HH 38 WX 40-Channels Handheld CB Radio Logo
226 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
