Question about Refrigerators
The freezer isn't cool enough and the refrigerator temperature goes up when we put stuffs.
  • ajay402 May 21, 2011
    The fan in the freezer below the ice maker isn't running. The back panel did have a bit of frost so I emptied the refrigerator, turned the thermostat to off and left the door open for 12 hours. Didn't see water dripping the floor. Put the refrigerator back on for 12 hours and more but the freezer temp didn't go below 8. The refrigerator temperature was 38. With less stuff in refrigerator the temperature goes down but goes up when we put more stuff. Seems like circulation problem. I took the freezer panel and ice maker off and now when I power on, I can see that the fan isn't running. What is that fan called (below ice maker above the silver coils). It is only connected with one green wire form the bottom so should not be big deal to change it. Thanks for your help. Running down to get a multimeter to run some tests as suggested by appliance-repair-it com. Is there any way I can share pictures/results with you and talk/chat/email one on one. Don't mind paying a little bit if I can avoid asking a technician to come down my place.
  • Refrigerators Master
  • 8,220 Answers
I would first look under the ice box for signs of air restrictions. Clean out the bottom and make sure the fan and compressor is working. Inside the ice box listen to see if the fan is running in there. If that is fine I would look for signs of frost on the back wall of the freezer. If frost is present then ice is on the coils and you have a defrost problem. Their are 2 basic circuits in an ice box. Compressor run AND Defrost run. Compressor run circuit is anywhere from 8 to 12 hours depending on manufacturer. Defrost is 21 minutes. On new fangled electronic ice boxs the brain decides when defrost is needed using inputs from sensors, compressor run time, and how many times the ice box is opened and closed. But the new fangled ice boxs still have a defrost heater and thermostat like any ice box with automatic defrost has. Why do we need a thermostat? The heater is very powerful. It could easily destroy the ice box. It takes only moments to elevate the crawlspace inside the evaporation compartment to 50 degrees F. This keeps any frost that could turn into air flow blocking ice at bay.
Remember the defrost time is 21 minutes. If that heater was left on for 21 minutes it would not be purty. The termination thermostat is recommended to be replaced if it goes bad or whenever the heater is replaced. I say replace all 3 things in the circuit and be done with it. But who these days can afford that? If you suspect a defrost problem just unplug the ice box for a day or 2. If the ice box goes back to performing ok then you can suspect you indeed have a defrost problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 21, 2011
  • 1 more comment
  • Dan Webster
    Dan Webster May 21, 2011
    A lot of folk think it might need freon added but all these other things need to be addressed first.
    In 99% of cases freon is not the problem. The unit only holds 4 ounces. If a leak were to happen in a few day you would have 0 cooling. Not some cooling.
  • Dan Webster
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
I have cleaned out the refrigerator and it still doesn't cool enough to freeze the ice and the bottom isn't cooling enough either even after putting the temperature up.What can I do next?
Have you cleaned off the fins at the bottom of fridg? look on back at bottom and bottom front. Take off covers and see if fins are dusty if so vacume off be careful not to damage fins.
Jul 07, 2012 | Refrigerators
Nt side by side fridge freezer not freezing
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 22, 2012 | Hotpoint Refrigerators
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Samsung Refrigerators
The freeze has ice build up on the back wall and the temperature isn't cold
heatman101
Jul 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a sub zero 561. The freezer works properly but the refrigerator is not cold enough. I turned temperature from 5 to 7 but no change
heatman101
Jul 05, 2011 | Sub-Zero 561 / F
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
