Computers & Internet Logo
Posted on May 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green light is on - when select print nothing happens - print queue shows printer not responding
Emmanuel Borja
Level 2:
Sergeant:
  • Expert 167 Answers
  • Posted on May 21, 2011
Emmanuel  Borja
Expert
Level 2:
Sergeant:
Answers
167
Questions
0
Helped
35093
Points
518
Go to control panel then choose printer the set the printer model you are using to default then try to print again or check the cable if properly connected and lastly re install the driver if needed
2helpful
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
I have Windows 7 and I found that running troubleshoot on the printer works most of the time and keeps me from having to shut everything down.
Go to
  • Control Panel>Hardware and Sound>Devices and Printers
  • In the upper left of the window select File
  • In the drop down list select Troubleshoot
This usually fixes the problem, really empties the printer queue, and I don't have to shut everything down.
2answers
Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
It just won't work. The light is green but I send a document to the printer and nothing happens. When I turn it on the light is red but if I put the "job cancel" button it will got to green.
Go to "Printers and Faxes" in the "Control Panel" and check to see if your printer shows any documents waiting to be printed, Cancel these documents and Right click your printer icon
select "Properties" and select "Print Test Page" to test your connection...For varies reasons documents sometimes fail to print and the printer queue backs up
2answers
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
1helpful
2answers
My printer will not respond to my laptop to print
The print queue is jammed.
If this is on a network, call your administrator to clear the queue for you, if this is a local printer, you must do as follows:
1. shut down the printer
2. disconnect the power cable and the network/ usb/ parelllel cable
3. wait 5 minutes
4. put it back together
5. power the printer back up.
Good Luck!!!!!
Problem printing from my acer aspire one
Can you provide a little more information. Is the printer green power light on but neither of the red lights. Does the printer just sit there doing nothing, or does it go through the motions of printing and produce a blank sheet. If it does nothing, can you check the print queue (double click the printer icon). If there are a mass of jobs waiting (all the times you've attempted to print something), right click and select cancel all jobs. When the print list is clear, right click the printer icon and select properties. Now click on test print. If nothing happens as before, cancel this job also. Then go to control panel and uninstall the Epson printer software (the "driver"). Reboot and reinstall the printer driver. Report back if it's still not behaving.
Printing
If you're using Windows, first make sure the print queue is empty by going into Control Panel, Printers and Faxes. Select your printer and delete any documents that are showing there. If there is nothing showing there, then unplug the printer's power cord for a while to clear its memory.
1helpful
2answers
HP photosmart C3180 stops printing
Posted by JACOB I understand that you are unable to print and when ever u try to print the jobs stuck in queue... When we right click on the icon if we see a option use printer online this shows that the printer is offline, if we see a option use printer offline in the list then this shows that the printer is online status. To resolve the issue we have to first clear the job in queue. Open the printer folder and then double click on the HP printer icon this will show the jobs in queue just right click on each job in queue and select cancel to clear the job in queue if there are still jobs in queue we have to performe the restart the print spooler steps by keeping the usb cable disconnected so that all the jobs are clear when the spooler is restarted. One the spooler is restarted just reconnect the usb cable and check if there are any jobs in queue. If there are no jobs in queue we can move ahead an set the print directly settings. Steps to set the print directly settings: Right click on the printer icon and select properties then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print to check with the issue. If the issue presists you can try to check with the port settings. Right click on the printer icon and select properties and then click on the ports tab and check if the virtual usb001 port is selected if not select it and click on apply and ok to save the settings if you don't see any usb port check if you have dot4 port in the port list select it and save the setting and try to print this should resolve the issue.. Once done try to print and if the issue presists you can try to refresh the usb ports. This will re-detect the usb drivers for printer and you will be able to print after restarting the computer.
Grand Canyon Tech
Grand Canyon Tech
