Question about Refrigerators
Dometic rv refrigerator rm2652 not cooling, leaking green substance in the back access panel, no amonia smell. 1. what part of the refrig would this green substance be coming from? 2. can this be repaired,worn part replaced or new unit?
  • filmores May 21, 2011
    I just called dometic and this model is on the recall list. so I will speak with them on monday about necessary repairs and go from there. Thanks for the info.
  • 10,515 Answers
Many recalls for both dometic and Norcold have been issued in the past.There is a chemical called sodium chromate in the solution that circulates inside the cooling unit. It is there to prevent the ammonia/hydrogen/water solution from corroding the steel tubing. If a leak develops, this chemical changes from a liquid state to a powder in the presence of air. A yellow / green residue on the outside of the cooling unit indicates a leak. And the cooling unit is bad....... Also if the unit sat for a long period of time UNLEVEL then you could have blockage,the refrigerator depends on gravity to move the solutions through the system once the heat source has lifted the solutions to the top of the cooling unit. The passages that the solution must travel through have only a slight slope to them and any off-level condition will hinder this gravity flow.I would rather advise you to call the manufacturer and check if there is any recall. Unless, they could tell you the quote to change the cooling system. You could take a decision from there. A thumb rule - if the cost of the repair is more than half of the cost of the product, it is wise to switch to a new unit.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 21, 2011
Refrigerator not cooling on electricty or gas
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Mar 15, 2014 | Dometic DM2652 Americana Fridge...
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
My Dometic refrigerator model # Rm2652 does not cool anymore. The element heats up on both gas and electricity. I noticed an amonia smell and there is yellow matter at the bottom of the stack where the...
Your cooling unit is done, and will need replacement. I will urge you to take down model and serial number and go to their site, or call Dometic , ( www.dometicusa.com) 1-800-544-4881, and inquire whether your unit falls into the recall on some of those models. You may end up with a new cooling unit, free of charge.
May 23, 2011 | Dometic RM2652 Refrigerator
Dometic RM 2652 Doesn't Cool smells of amonia
There is a recall on this product. Go to www.Dometic.com and look for the recall info...or try this link http://67.238.126.140/recall.php put in your model and serial number to see if yours if a recall...I believe it is and I have found the problems you are talking about at this website http://www.gasrefrigeration.net/Why%20they%20fail.htm. which is exactly why they are recalling this model refrigerator. Hope the links help...if not go to the first link and look for the recall page and you will be able to see if it applies to your rv refrigerator. Hope this helps!!!
Sep 14, 2010 | Dometic RM2652 Refrigerator
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
I have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Jun 06, 2010 | Dometic RM2652 Refrigerator
My Rm2652 Refrigerator in my Rv just quit cooling. The electric element checks good and heats as well as on gass. I did not smell any amonia odor from a leak and have not taken it out and turned it upside...
You need to have 12 volt supplied at all times to make it work
Check to be sure you have a good 12 + and a good ground.
Lots of times the coolant leaks without you smelling anything Slowly over time
Mar 06, 2010 | Dometic RM2652 Refrigerator
Dometic RM2652 will not cool on A/C or propane, I've checked fuses, and AC to refer. I opened the access panel on outside of Travel Trailer, and there is yellow powder on bottom, and some on heating tube....
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
Jun 07, 2009 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Fridge not cooling
If you look in the outside compartment do you see a yellowish powder? If you do, or if you smell amonia probably the cooling unit has leaked the coolant. It does not help to add coolant, it will just leak out again quickly. You will need a new fridge or to have the cooling unit replaced. If that is the problem, Dometic has a recall on some models for leaks and will pay for a new cooling unit.
Jun 12, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
