When I first turn tv on there are several white horizontal lines across the top part of tv. They disappear after tv is on a while.
    Sergeant:
  • 167 Answers
Please check if the power outlet have the proper power output, low current have that effects to the flat panel TV
Posted on May 21, 2011
My tv has several white horizontal lines running across the top of the tv screen the tv brand is an Insignia SDTV and its an older tv what can be done to remove these lines?
This is a retrace blanking problem. Probably, the Vg2 voltage is too high, so the cut-off point from the picture tube is not correct. Try to lower this voltage. On most common flyback trafo's it is the lower adjusting screw (plastic kind of button) which is used to set the Vg2 voltage. Turn it a bit CCW until the white lines disappear.
Jun 14, 2014 | Televison & Video
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
Horizontal lines LED hisense tv
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Hisense Televison & Video
White line across screen
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
WHITE horizontal lines across screen
You need to adjust Screen voltage (decease a bit) to disappear white lines on TV. If you want to do it yourself, let me know to help you further.
Regards,
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Horizontal lines across the top 2 - 3" of the screen
Sounds like you have some capacitors that are needing to be changed in the vertical circuit. The cost I cannot quote but, it probably won;t be worth the cost as replacement TV's are much cheaper now. Zeniths and other brands for the longest time have used not controls inside the TV, they are technician adjustments through a service menu only.
Apr 19, 2007 | Zenith C27A24T 27" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
