Question about Refrigerators
Whirlpool gb22dkxgw00 refrigerator lost all cooling. Defrost timer seems to work. Plug unit in and 10 seconds later, I think the compressor starts, but shuts off after 5 seconds. Drain tube open, replaced starting relay. Keeping the unit plugged in produces a hot compressor, but no noise or vibration in compressor. Freezer thermostat shuts the unit down on "off", turns back on when put to the "1" position.
peyton32034
  • 410 Answers
SOURCE: Loud banging noise and water leaking
first of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
fwiw: whirlpool in my opinion is probably one of the best appliances on the market..
Posted on Dec 13, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
SOURCE: Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Posted on Jun 13, 2008
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
I have a Kitchen Aid refrigerator model KTRS20K which stopped working (everything felt warm and freezer not working ). I replaced the defrost timer, it didn't quite match but was told it was a re
That does not sound like a defrost timer problem. Sounds like a condenser or evaporator fan is beginning to fail. They don't always stop when they fail. Many will slow down and stop while you are not looking causing the refrigerator to stop cooling for a while. Let me know if you have any questions, Thanks Sea Breeze
Feb 12, 2012 | KitchenAid Refrigerators
Whirlpool gb22dkxgw00 is the model number of the fridge in question. As asked to tbirdfan with a reasonable explaination, I was not aware I could not follow up with questions without an additional charge....
you paid for someone to tell you to jump out the defrost timer when all you had to do was advance it with a screw driver to put it into defrost and if you wanted it out of defrost when you heard it click and the fans came on guess what it's out of defrost,you should ask for your money back,i can't believe someone told you to jump out the wires on the timer,if the problem is the compressor isn't running change out the start device like i told you
May 18, 2011 | Refrigerators
I have a kemore coldspot side by side maufacture date 04/07 that is not cooling properly. Freezer gets cold but won't freeze and fridge section gets cool. I have checked condenser fan runs and compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Kenmore 53642 / 53644 Side by Side...
My refrigerator and freezer will work fine for a day or so, and then cool poorly. The compressor runs continually when it cools poorly. If I unplug it and plug it back in a few seconds later it will run...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 30, 2010 | GE Refrigerators
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
Whirlpool GB22DKXGW00 stopped working while connected to a power inverter during a recent power outage. The light still works so I know it's not an outlet issue. Fan's not moving, no humming, just silence.
I would check your defrost timer it will be located at the bottom of the ref under the kickplate. You can manually advance it by hand and see if the unit will kick in. If this doest not correct the problem then I would assume that you have a bad temp control or a shorted compressor winding. You can try tapping on the control panel by your temp control with the back of a screwdriver and see if the unit will kick in. Hope this helps _MJ_
Mar 04, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a ARB2205CS that is 6.5 yrs old. It stopped
No, the relay was what caused the buzz click but i think a bad compressor could be responsible for blowing the relays out. If you had a bad defrost timer that was stuck in defrost thus compressor not running you would not get the buzz click..your comressor would also be cold.
Jun 23, 2009 | Amana ABB1927DE Bottom Freezer...
My Kenmore fridge, Model 596-58692890 is not cooling and I've lost use of the water/ice dispenser. The motor and compressor seem to be working but the cool air is not blowing. What part might need to be...
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 24, 2009 | Kenmore Refrigerators
Whirlpool not cooling properly
I would expect the defrost timer to stay in defrost 21 minutes. IT seems your timer is normal.
If turning the ref section temp colder made compressor come on, it could be that the thermostat is worn a little and just needs to stay on a little cooler setting. Check the freezer temp dial and It should be at just slightly more than 1/2 of available setting. If there is A B C you would want to be a little cooler than B about B and 1/4.
I hope this helps K S
Nov 22, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
