Question about Samsung Televison & Video
I connected my tv with DStv decoder but it shows in black and white.using component port is ok but Using AV port that problem occurs..(my decoder does not have component output.) Please help Dan Kenya.
SOURCE: Black and white on av channels?
fixed problem by replacing board on control side
part sourced for £85
now all ok
Posted on Jul 10, 2008
SOURCE: My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Posted on Jun 11, 2010
SOURCE: no signal from dstv decoder
no signal for dstv for my decorder pls help me.
Posted on Mar 20, 2011
jerryg50
  • 1689 Answers
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
SOURCE: Sony KLV-26U300A + xBox 360 setup help needed!
SHEARCH eeprom memory dumps
Posted on Jun 21, 2009
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
How do i reset av and tv chanel on Samsung Series 4 PS42C430 42
i activate av1,av3 and av3 in service. my tv come on and off. i can't inter in service. samsung 42, PS42C430, SO HELP ME HOW TO DEACTIVE AND INTER IN SERVICE.
Jun 19, 2012 | Samsung PS42C430 42 Plasma TV
Im trying to hook up a HD A/V combo cable to my led jvc and the tvs missing one connect part. Im only gettinf black and white but the guy insisted that it was the right cord. What cord do I need?
You don't need a ikonvert box if you tv has a AV out (monitor out on picture) then all you need is an AV cord sorry if this is not helpful
May 25, 2012 | JVC Televison & Video
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
What to do:
  • AV Cables
  • Component Cables
Still Not Resolved:
Mar 06, 2012 | Nintendo Wii Console
I'm not able to connect my dstv decoder and dvd player onto my samsung 51"plasma tv because there's only one AV plug. Can you please help?
  • i cant connect my standard decoder to samsung 51inch as ther are only ports compements and hmdi,do i need a pvr decodr?
Jul 12, 2011 | Televison & Video
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
Sep 03, 2010 | Televison & Video
Can't pick up signal on the other room for my dstv
chances are your problems lie with your connections themselves, most cases its with the splitter box if you are using one, if u are then rather remove the splitter box altogether, u will then need a set of RCA cables (the red white and yellow cables that come with DVD players) use these to connect the first point directly from the decoder to the TV using a free AV input behind the TV. form then on proceed to connect the cable going to the room directly to the RF OUT port behind the decoder (make sure the copper and aluminium wires dont end up touching, but use both, the copper on the inside and the alu on the steel outer casing) if this doesnt work check your connections and if all fails replace the cable as a last resort
Oct 08, 2009 | LG DR787T DVD Recorder
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Televison & Video Logo
571 people viewed this question
Jerry Greenberg
Jerry Greenberg
