Network controller - Computers & Internet
    Sergeant:
  • 167 Answers
Try to reset the router to the manufacturers default. and try to set it up again
Posted on May 21, 2011
What does fault code u041800 mean on 2011, 1.6tdci Ford Focus? What causes it and how can you fix it?
U0418 Ford Invalid Data Received From Brake System Control Module
Your best bet , take it to a qualified repair shop . Do you know anything about serial data communication networks ? C.A.N - controller area network ?
How to Diagnose Controller Area Network CAN
Communications Network Vehicle communication utilizes both medium and high speed controller area network (CAN) communications. CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
The vehicle has 2 module communication networks:
  • Medium speed (MS) CAN
  • High speed (HS) CAN
Both networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on both networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
Jun 12, 2017 | Ford Cars & Trucks
On my 05 Ford mustang v6, my fan only comes on when i turn my AC on and makes a funny noise when I turn the AC on, diagnostic test gave me a code, u1900, what does this mean and how do I fix it?
Where did you pull this code from ? What type scan tool did you use ,or was it a code reader ? Do you know about data communication networks on modern cars ? A U codes indicate a communication problem on the data network .
U1900 CAN Communication Bus Fault-Receive Error Audio Control Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error ABS Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Instrument Cluster REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error SJB REFER to Section 418-00 . The thing that would make this easier to diagnose would be to have a factory scan tool or a professional grade . Need to know what modules can communicate with scan tool .Honestly ,Don't think you can fix this . Dealer or ASE certified repair shop .Do you know what C.A.N. - controller area network is ? The vehicle has 3 module communications networks:
  • high speed controller area network (CAN)
  • medium speed CAN
  • international standards organization (ISO) 9141 communications network
The diagnostic tool connects to the communications networks through the data link connector (DLC). The DLC allows a diagnostic tool access to diagnose and test the vehicle systems of any module on the communications networks.
All 3 communications networks are connected to the DLC. This makes diagnosis and testing of these systems easier by allowing one diagnostic tool to be able to diagnose and control any module on the 3 communications networks from one common connector. The DLC can be found under the instrument panel between the steering column and the driver door. Which module doesn't communicate with scan tool ?
Symptom Chart Condition Possible Sources Action
  • The anti-lock brake system (ABS) module does not respond to the diagnostic tool
  • Circuit or connection in the high speed controller area network (CAN)
  • ABS module
  • Go To Pinpoint Test A .
  • The audio unit does not respond to the diagnostic tool
  • Circuit or connection in the medium speed controller area network (CAN)
  • Audio unit
  • Go To Pinpoint Test B .
  • Audio unit
  • The instrument cluster does not respond to the diagnostic tool - high speed controller area network (CAN)
  • Circuit or connection in the high speed CAN
  • Instrument cluster
  • Go To Pinpoint Test C .
  • The instrument cluster does not respond to the diagnostic tool - medium speed controller area network (CAN)
  • Circuit or connection in the medium speed CAN
  • Go To Pinpoint Test D .
  • The powertrain control module (PCM) does not respond to the diagnostic tool
  • PCM
  • Go To Pinpoint Test E .
  • The restraint control module (RCM) does not respond to the diagnostic tool
  • Circuit or connection in the international standards organization (ISO) 9141 communications network
  • RCM
  • Go To Pinpoint Test I .
  • The smart junction box (SJB) does not respond to the diagnostic tool
  • SJB
  • Go To Pinpoint Test F .
  • No high speed controller area network (CAN) communication
  • High speed CAN modules
  • Go To Pinpoint Test G .
  • No medium speed controller area network (CAN) communication
  • Medium speed CAN modules
  • Go To Pinpoint Test H .
  • No international standards organization (ISO) 9141 communications network communication
  • Circuit or connection in the ISO 9141 communications network circuit
  • Restraint control module (RCM)
  • No module/network communication - no power to the diagnostic tool
  • Data link connector (DLC) C251
  • Bussed electrical center (BEC) fuse 4 (30A)
  • Smart junction box (SJB) fuse 8 (10A)
  • Circuitry
  • Diagnostic tool
  • Go To Pinpoint Test J .
Apr 11, 2016 | Ford Cars & Trucks
How do i turn off the wifi
To turn your wireless network adapter off through the Network Control Panel:
- In Windows XP, click Start > Settings > Control Panel > Network Connections.
- In Windows Vista, click Start > Control Panel > Network and Sharing Center > Manage Network Cnnections.
- In Windows 7, click Start > Control Panel > Network and Internet >Network and Sharing Center > Change Adapter Settings.
2. Right-click on the wireless network connection and choose Disable.
HOPE THIS HELPS...
Oct 01, 2014 | Gateway M360 M460 M680 MA2 MA3 MA7 CD DVD...
Whats the network lock control key for telstra
Do you want network unlock control key for your samsung gt-s3850 mobile phone? Yes means you can visit this site Unlock-Zone.com here you can get the network unlock control key (unlock code )and unlock your mobile easily. To get the code you have to mentioned which country is locked now,network provider,which country is locked now,network provider and imei number. Then they send unlock code through email.
Unlock-Zone.com
May 26, 2014 | Samsung Galaxy Ace GT-S5830
Turn on the wireless switch without using without using Fn Key?
  1. Click the "Start" button, then click the "Control Panel" icon on the Start menu. This opens the Control Panel window.
  2. Step 2 Click the "Switch to Category View" link in the left-side pane of the Control Panel window if the window is not already set to category view. You will see the "Network Connections" icon in the right-side pane. Double-click this icon to open the Network Connections window.
  3. Step 3 Right-click the icon for your wireless network adapter in the Network Connections window, then click the "Properties" link in the context menu. This opens the Wireless Network Connection control panel.
  4. Step 4 Click the "Wireless Networks" tab in the Wireless Network Connection control panel. Check the box next to "Use Windows to configure my wireless network settings."
  5. Step 5 Click the "OK" button in the Wireless Network Connection control panel. This completes the process.
Dec 02, 2009 | Office Equipment & Supplies
No ethernet controller
Here are a couple of solutions to your problem.
The network adapter has been disabled in the BIOS
and/or
The drivers for the network controller has not been installed.
To check the network adapter go to the Control Panel, Click on System, click on Hardware Tab then Device Manager. Then scroll down and click on Network adapters. If you don't see your network controller or you see a yellow ? against Other devices for the Network controller. Then either it has been disabled and/or the driver was not installed.
To get the driver for the network controller you need to dowload it from the IBM/Lenovo WEB site their support/download page from a computer that has Internet access. Make sure you select your laptop model and the driver for your Windows version.
Jan 22, 2009 | IBM ThinkPad T23 2647 Notebook
Windows xp no longer recognizes my wireless antenna/program
To change windows to the controlling program, click on Start, then head over to Control Panel. Under Control Panel, double click on the icon for Network Connections. There, find the Wireless Network Connection. Right mouse click on it and go to properties. After the Properties Window pops up, Click on the Wireless Networks Tab. There, check mark the box which says "Use Windows to configure my wireless network settings." This will activate windows control over the network card. Hopefully this helps.
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Network Controller is unavailable
The network controller used on these machines has a 2 stage power supply. The 1st stage initialises at switch on and the 2nd stage at about 75% of the boot sequence, if the 2nd stage fails then you will get the "controller unavailable" message. The answer is to replace the internal power supply for the network controller.
Apr 29, 2008 | Xerox 5665 Copier
Computers & Internet Logo
David Payne
David Payne
