Question about Goodman Heating & Cooling
I have a condensing unit model # ce19-1ed and serial # 9212063303. can you tell me how many ton it is
  • 3 Answers
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
  • 20 Answers
SOURCE: can't identify ton rating of condenser unit
the model number tells me it's a 4 ton. the 048 is what it gives it away. 1 ton is 12,000 btu's . 4 ton is equal to 48,000 btu's
Posted on May 23, 2009
FunnyPlumber
  • 43 Answers
SOURCE: I need to know the btus of a carrier condenser
48,000 BTU's
Posted on Jun 23, 2009
james3751
  • 614 Answers
SOURCE: Can Air Handler !1/2 ton run with 2 ton
Its done all the time. It is sometimes better to do this because you run a colder coil and rmoves more humidity. The newer unit have variable speed fan and run slower to do the same thing. Remember the lower the humidity the higher you can raise your tsta. Example In arizona at 95 degrees you dont feel the heat as much because of the lower humidity. Its ok to do so. You get more btus out of your unit that way. Rus. I have dozens of units with air handlers 1/2 ton smaller...
Posted on Jul 18, 2009
  • 1169 Answers
SOURCE: how do i tell what ton my ac condensing unit is by
get me the model number and I'll tell ya.
Posted on Feb 03, 2010
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
Need Minimum Circuit Ampacity and the Maximum Fuse Breaker for the Condenser - Thak you
Serial numbers don't tell much.
Model. numbers describe the unit best an 18 in the model is for 1 1/2 ton,24=2 ton, 30 =21/2 ton 36=3ton etc
May 02, 2015 | Heating & Cooling
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY...
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Aug 04, 2010 | Honeywell International Heil Quaker...
How many tons is the condensing unit serial # 10AJB36A01
3 tons. 12,000 btu per ton divide 36 into 12 = 3 tons
May 19, 2010 | Heating & Cooling
Can't identify ton rating of condenser unit
May 23, 2009 | Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Someone has an Intertherm outside 3.5 ton a/c unit for sale but doesn't know anything about it Model 5SQD-042KA Serial S5A070500546 Can you tell me how many SEER, heat pump or not,...
There should be a square sticker or metal plate that tells you the model # the #'s that comes close to the multiplecation of 12 =to tonnage,example ( asbv036g-1 the 36 = 3 tons 12x3=36 (gdhe420-1 = ==3-1/2 tons cooling 12x3 plus 6-1/2 ton = 3-1/2 tons the serial # tells the year it was made.....080808 , the first 4-#'s tells you the month--- for 4 #'s this is aug.- year 08 !
Sep 05, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
