Question about HP L1702 17" LCD Monitor
My monitor keeps saying going to sleep and wont come on
    Guru:
  • 767 Answers
Mark_Webber
  • 472 Answers
SOURCE: Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Posted on Apr 09, 2008
SOURCE: monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Posted on Oct 10, 2008
sys_admin
  • 829 Answers
SOURCE: My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Posted on Jan 14, 2009
tinualbinale
  • 436 Answers
SOURCE: my monitor keeps saying monitor going to sleep
It shows that the monitor is going to the power saver mode.It is not a problem of the monitor.This happens when there are no signals received on the monitor.It turns back to the normal mode when a signal is received on it.
Posted on Mar 21, 2010
ErusTownsend
  • 592 Answers
SOURCE: monitor is sleep mode how
You can move the mouse or press the keyboard keys.
If this happens in the middle of using the computer than either your video card drivers are damaged, video card is damaged, monitor is failing, connection (wire) to the monitor is damaged or not connected correctly.
Posted on Mar 02, 2011
Monitor keeps going into sleep mode
try a different monitor / tv (some have pc hookups) and see if it really is your monitor or your PC not providing a signal
Sep 02, 2014 | Compaq Computers & Internet
My HP monitor keeps going to sleep,it reads (power button lockout) How do I fix this?
This is because the monitor's Power Button Lockout function is enabled. Press and hold the Power button for 10 seconds to unlock the Power button function. Your sleep problem should also be related to the lockout issue.
Dec 13, 2013 | HEWLETT-PACKARD Pavilion p6520f PC Desktop
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | HP Q1859 18 inch Monitor
Hello
I FIX LOTS OF COMPUTER, AND MY ADVISE IS. IT MIGHT BE YOUR COMPUTERS VIDEO CARD CAUSING THAT PROBLEM . ALSO CHECK FOR VIRUSES THEY CAN DO STRANGE THINGS.
Mar 17, 2010 | Computers & Internet
My HPw1707 monitor keeps going to sleep and I have to turn off the computer to get the programs to open when I want to work on anything.
Are you saying that the monitor is going to sleep or the computer? If the computer goes to sleep I can understand not being able to get to your programs. This is a simple matter of turning off hybirnate in the power supply icon of your control panel. If the monitor is going to sleep there should be a menu with a timer for sleep time. Just change it to a much longer time or turn it off.
Feb 25, 2010 | HP Computers & Internet
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Jan 14, 2009 | HP w2207 Monitor
HP L1702 17" LCD Monitor Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
