Question about HP Office Equipment & Supplies
I just changed all of the ink cartriges. Now the magenta and Cyan are not functioning....nothing. Everything is yellow and black, I cleaned the print heads twice, just wasting ink. I tried to align the print heads but that failed several times, I'm ready to throw it into the street
    Brigadier General:
  • 10,406 Answers
If it worked before changing the ink-cartridges, then it probably is _NOT_ a case of "clogged" ink-jets in the print-head.
Did you remove the plastic "sealing" tape from the new cartridges, before you installed them?
If not, then no ink can leave the cartridge.
Which model of HP printer? Maybe, you got a "dud" of a new ink-cartridge.
Take it out.
Take an old, thick, section of newspaper, and lie it flat on your table.
Dampen a paper-towel, and put it onto the newspaper.
Touch the ink-cartridge to the paper-towel -- it should "bleed" some ink onto the towel.
Not much ink, but the newspaper is there to protect the surface of the table.
If no "bleeding", then the ink-cartridge is the problem.
Posted on May 21, 2011
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
My printer prints in green not other colours
Most printers have 4 color inks: Black, magenta, cyan, yellow.
If your magenta ink isn't printing, then your prints will have a green cast.
If your printer has a "nozzle test", I suggest doing that. If it has a "head clean" function, that may help.
Replacing the magenta ink cart may be all that's needed.
Jun 20, 2015 | Office Equipment & Supplies
HP Officejet Pro K8600 won't print in color, just in black
Ink levels are an estimate. They are approximated according to how much color might have been used. You may be out of all the color inks, they may be dried out or clogged. There should be a head cleaning operation for the printer, but it uses ink too.
Feb 07, 2018 | HP OfficeJet Pro K8600 Printer
When I print the Black ink does not print on page at all. All of the colors cyan, magenta and yellow are fine. I haver replaced the Black Cartrige and Run the printers cleaning cycle several times.
maybe you run out of ink for black, try to use other ink, if its still the same then their a stockup ink on your head of the printer and better to replace it. I think once you purchase an ink cartridge of cannon their is also printer head included. Hope it helps thanks.
Sep 19, 2011 | Brother MFC 490cw Color Inkjet...
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Wont print ANYTHING if ONE ink cartrige is out
need to replace all to! some printers are like that wont print unless all inks are full and inplace!
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
