Question about Garden
After about an hour or less the right control on my Troy Bilt zero turn quits working and no longer powers the wheel. After it sits for a while it starts working again. Any ideas?
  • 776 Answers
Option 1
The belt to the transmission that controls the right wheel is slipping because it is worn out or too loose. I believe this is the most likely answer. Turn the mower off, put the key in your pocket and then check if the belt is glossy or cracked. Also see how much you can move the belt. It may need to be replaced.
Option 2
The tranmission for the right wheel is damaged.
If this is the problem, it could get expensive and you will have to decide how much money you want to spend reparing this problem.
-Mark
Posted on May 22, 2011
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Troy Bilt Lawn Tractor won't turn left - still turns right
hi, mam i want to solve this prolem try contact or text this number 0927642929 / ( 032) 5127262
Sep 11, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
Left wheel has lost 75% forward/backward power.
fluid level but if its that new it should have a warr
Apr 26, 2012 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
The tiller was working fine for about an hour. I let it rest for 15 min, then briefly turned it on its right side work on left wheel. It started right up, but then stalled about a minute later and won't...
Laying your tiller of its right side can fill engine breather with oil and possibly entering your carburator causing engine to smoke and then quite. If this is so change or clean your spark plug. It this is not the case your crankshaft seal may be bad allowing oil to enter your ignition point and condenser cavity causing points to get wet.
Mar 19, 2011 | Troy-Bilt Pony Garden Tiller
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
