Question about KitchenAid Washing Machines
I had an approximately 5-6 " spring broken off. I bought a replacement but have not been able to find out from where to where does this spribg hooks up. I understand it is called a counter balance springs and it comes in a package of 3 clored springs green, blue and silver and should match the motor label color. I have not been able to locate any literature or picture that shows where this springs is suppose to go.
  • carlos_cfac May 21, 2011
    Model Number is KAWS850LQO. The spring shown on the video you sent me are the heavy duty support springs and there are three of them. The spring I'm refering to is not so heavy duty and is the only one. One side has a short hook and the other side has a 4 to 5 inch long straight wire with the hook at the end. It was broken when I took the washer appart and at the bottom so I have no idea where it came from. I think it is called a counter balance spring.
    Thanks,
    Carlos
  • carlos_cfac May 22, 2011
    This is great. I wish I would have known about this service last year when I had to pay $165.00 for a Sears tech to come to my house to replace the suspention springs that I had bought already because I did not knoe w\how to take the machine apart. Great service for the DIY home tech.
    Dave your second video was right on and answered my question.
    Thanks a million.
    Carlos
  • 4,323 Answers
Hi
Please check the video for suspension spring replacement--
Hope this helps... Please post back with model# if you need more information.
Daniel
Posted on May 21, 2011
  • Daniel Scott
    Daniel Scott May 21, 2011
    Carlos, please check this video:
2006 Kawasaki ZZR 1400 won't shift
Hi, Edward and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
won shift up to 2nd
Shift Lever is stuck Cant get past 2nd Kawasaki Forums
Kawasaki 2007 ZZR1400 Service Manual
OEM Parts for Kawasaki
Kawasaki ZZR1400 Owner Manual
Jun 10, 2017 | 2006 kawasaki ZZR 1400
My 97 royal star is stuck in second gear, I just bought it was st ride exept not 1st gear , it looks like someone just changed clutch
Hi, Janice and the usual suspects are:
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
shifter still stuck
The Venturers Yamaha Venture Technical Support Library
Yamaha XVZ13TFL Service Manual
OEM parts for Yamaha
YAMAHA XVZ1300A Owner Manual
Apr 29, 2017 | Yamaha Royal Star XVZ 1300 A Motorcycles
How do I get and replace the carrier for my color cassette? The spring is missing, and the locking mechanism is broken.
Best take it to a repair shop, do get a written quote , as some times it is cheaper to bye a new or second hand printer.
Mar 03, 2016 | Office Equipment & Supplies
Repair beeman rs2 broken spring
My stupis Beeman RS2 dual-caliber Air rifle combo trigger broke for no reason and I cant find a replacement can someone help me?
May 29, 2012 | Beeman RS2 Dual-Caliber Air Rifle Combo...
I have a Lavazza espresso point machine and I need a wire spring to replace the old one which broke. The spring helps close the "doors" onto the capsule when you introduce it in the machine....
Which of the Jaw spring is broken? Left of right, is essential to know, they are not the same. Where are you located? I have some parts or I could give directions to a dealer near your home. Guru.
Sep 23, 2011 | Lavazza Espresso Point Capsule Machine
Shifter lever won't return to the " center " position always. The problem is intermittent and seems to occur more in the heat. I've heard there may be something binding the mechanism....
Follow the shifter reach rod that runs from the shift lever back to a short lever on the transmission. Take the nut off and take the rod loose from this short lever. Then, move the forward like you are going to shift into low gear but don't actually shift the transmission into gear. Feel for the spring tension. Then, move the lever backwards and feel for the spring tension there. Check the shift lever and the reach rod for binding. If you don't feel the spring tension trying to return the lever back to the center, it's likely that the shifter pawl return spring is broken. This spring is what returns the shifter lever back to 'center". But,the temperature of the transmission will not change this. If the spring is broken, it's broken cold or hot. If the spring is good and there is not bind in the linkage, the problem may be in the shifter cam mechanism inside the transmission. Either way, this is an internal issue in the transmission.
Good Luck
steve
Aug 20, 2011 | 2006 Harley Davidson FLSTNI Softail Deluxe
Hi, I've got a broken spring bar on my Tissot PRC 200 and would like to replace it. I understand that it has got a lug width of 19mm. Does that mean I should buy a 19mm spring bar, or should it be a...
Two of the spring-bars broke on the clasp of my PRS200, so I took it to an un-named watch repair shop that was closer than the Tissot-authorized store (Leslie Gold Watch Co.) at which I bought the item 5 years prior. After the repair, the clasp kept popping off, so I took it to the Tissot store, and they told me that it was because the ends of the bars didn't fit properly. They replaced the faulty bars for me at no cost, and the watch has been sitting on my wrist fine for the last year-and-a-half.
Dec 15, 2010 | Tissot Watches
Underwood no. 5 typewriter doesn't advance when hit keys
the cord is shaped much like a shoe lace, and these make great replacements, a spare clip can be fashioned out of a paper clip, it's not a precision part. the spring if broken can be replaced with any clock style spring, i bought a wind up kitchen timer at the dollar store (same for the shoe lace) and took the spring from that. for $2.14, got mine working good as new
Nov 01, 2009 | Office Equipment & Supplies
Washing Machines Logo
95 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
