Question about Flojet 03526 144A Triplex Diaphragm 3526 Series Automatic Water System Pump
My water pump (flojet03526-144a) is leaking. I use it in my travel trailer. It is leaking from the end where the black pieces are screwed in. How do I stop it from leaking. I have screwed the pieces in as tight as I can get them but it still leaks. Seems to leak worse after I shower. I am running city water and do not have it turned on. The RV park hooked my water up without attaching a water regulator. I have now put the regulator on but the pump is leaking water.
    Sergeant:
  • 281 Answers
You can use Teflon tape on the threads or get some epoxy glue at an auto parts store,it comes in a clear tube about the diameter of a nickle.It's called block putty.Just take it out and knead it till it turns whatever color the instructions call for.A local hardware store will have the Teflon tape.Try the tape first and make sure the threads are OK.I have used the putty on my water cooler and on leaking pipes under the sink.One time use it to fix an oil leak on an engine in a car.Thank you for choosing FixYa.com.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 21, 2011
When i try to fill the fresh water tank the water runs out a hose under the trailer. Where is a shut off valve?
sad to say this but we have no idea as we see no make model year etc . but can suggest looking the unit over well with a flashlight . under seats in cabinets under sink etc .
Aug 31, 2015 | RVs
How do I change the toilet in my 1972 Golden Falcon travel trailer ?
  1. I changed one in my 76 recently. Loosen bolts on the side towards the rear of toilet. remove water line. (shutoff first) pull straight up to remove. I t is pretty easy.
Jul 16, 2014 | Kohler Home
Rv leaking water under neath
The statement is extremely vague. Is it a travel trailer or a motor coach? Motor coach could be dripping condensation from ac while in use. Is it fresh water and only leaks when connected to a hydrant? Does it only leak when sewage is dumped into the black water holding tank? In short, you must determine under what condition the unit is leaking. Then narrow down where it is leaking from and then identify the failed part. RV manufacturers do not publish plumbing diagrams so it is all visual in the diagnostic process.
Jun 16, 2014 | RVs
How to stop drain pipe from leaking on a 2014 shower 1985 lancr travel trailer
Is it leaking at a glued connection or a jam nut connection? If at the jam nut connection you may need to replace the jam nut washer to get a good seal. If it is a glued connection. You may get luck and reseal the connection by swabbing some ABS glue over the leaking area. ABS glue is thick black glue and may be found at your local RV dealership.
May 01, 2014 | Forest River 2012 Rockwood Windjammer...
Behind the water pump it leaks antifreze its not the water pump but the hose from the radiator hook up to this metal tube and goes to the water pump that join is leaking does it have a gasket in between or...
you talking about water pump bypass heater pipe the metal elbow piece to the water pump hosing.the metal elbow piece is held in place by small bolt or bolts you should have either gasket or o ring betwween where metal elbow mounts to water pump housing.replace the hoses also.some times the hose will be leaking not gasket or o ring at the metal elbow.make sure screw or screws not loose or missing to the metal elbow pipe.
Apr 17, 2011 | 1997 Geo Metro
2007 hot water heater leaking
You will be happier if you replace it
Repairs seldom last very long with this type of problem
Mar 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Jun 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water leak
If you remove the air grill for the inside part you will find four screws which when tightened compress the seal gasket under the outside to roof. It may be a case of these screws being somewhat loose.
Apr 12, 2008 | Coleman Mach 15 Air Conditioner
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Flojet 03526 144A Triplex Diaphragm 3526 Series Automatic Water System Pump Logo
490 people viewed this question
Top Flojet Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Flojet Boating Expert? Answer questions, earn points and help others
