Question about Cycling
14 or 16 inch boys bike (yellow). How do you raise the seat?
    Problem Solver:
  • 3 Answers
Lossen the tighting bolt/clamp and twist the seat up as you pull into the desired hieght, hold and tighten firmly but not over done becuase seat will turn with it...
Posted on May 22, 2011
How to remove the seat from 2002 Harley Fat Boy
Hi, Richard seat removal can range from the simple and obvious to the complex and baffling for the novice new Harley Davidson owner. Seems like the more expensive the bike is the harder it is to remove the seat. So let's start with the most expensive. 99% of all Harley seats have a male tongue in the front that slides into a female receiver that is either bolted or welded to the frame just behind the fuel tank. For this reason, whenever you are removing a seat you must always slide it backward 3-5 inches For Heritage Softails check for a bolt on each side usually under a flap on the seat. Then there is the seat strap that is secured on both sides, only one side needs to be removed. A single screw can secure it to the rear fender or it may have a bracket with two studs secured by nuts or knobs to fasten the rear portion of the seat. For Sportsters if you have a pillion pad or passenger seat that snugs up against the front seat there can be a screw securing the two to the rear fender, you have to get your hand in between the two seats and force the separation of seat material to see and gain access to the screw. For Touring bikes, there is the rear seat screw in the back that is the caboose of seat fasteners, usually a large chrome bracket, that screws into the rear fender. Care must be exercised in covering this shiny bauble with your hand during the sliding back procedure so as to "NOT" scratch the tour pack. So when all the hidden and mysterious fasteners have been removed, you need to lift it up in the rear, slide it backward a few inches and bingo you have mastered the impossible.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
How to REMOVE your Harley Davidson seat
Harley Davidson Softail Workshop Service Repair Manual 2000 2005 $7 very cheap
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak to me personally absolutely "FREE"
May 05, 2017 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
Need to find a new seat/replacement post for 24" Next PX 4.0 Boys Mountain Bike, Black
I am a privet bike repair shop the seat post is a 25.4 mm 9 inch log i have a used seat post in stock and a new seat in stock that will work with a next px 4.0 a had the same issue you contact me on my web site
May 08, 2015 | Next 24" PX 4.0 Boys Mountain Bike, Black
How do you raise the handle bars on the bike?
If it is an older bike, you loosen the bolt at the top of the handle bar shaft until it is about 1/2 inch raised. Take a hammer and give it a swift bump and it should drop into the shaft. Hold the front tire between your legs and the handle bar should raise up. Re tighten once every thing is lined up. If the bike has front hand breakes these may need to be adjusted.
Aug 05, 2014 | Generic 16" Raskullz T-Rad Rex Boys Bike
If Seat adjustment is possible in 2011cbunicorn
Your bike has a mono shock. It does have adjustments but it is for ride stiffness not necessarily ride height. But adjusting the rear shock will lower and or raise the seat a small amount. But at the lowest setting the seat height is still 792mm or 31.2 inchs. You may find a shorter shock but it would have to be from a parts search to match.
Sep 18, 2011 | 2011 Honda CB Unicorn
How do i raise the seat on a dynacraft tony hawk bmx bike
loosen seat post clamp with correct size allen. once its loose push down and twist the seat untill its where you want it then tighten the seat post clamp
May 17, 2011 | Dynacraft Tony Hawk Homer Boy's 20-Inch...
Seat assembly came apart out of the box and I need direction on how to assemble the seat mount components
Please go to my tips and tricks page. There are links to huffy's website for on-line assembly instructions and detailed owners manuals. Good website.
Dec 15, 2010 | Huffy Pro Thunder Boys 16-Inch BMX Bike
I cant remove the seat on my 87 gv1400
Remove the saddlebag lids, undo the 2 bolts just behind the shocks, one on each side of the seat. These are the only bolts that hold the seat on. Lift the rear of the seat about 6 inches to release the front tangs. Raise the front to the vertical and remove the 2 air lines from the front right side of the base and the one at the rear. Seat should now be clear of things attaching it to the bike. Join the worldwide Yahoo email group for these bikes via www.suzukicavalcade.com and ask some more questions.
Oct 03, 2010 | 1986 Suzuki GV 1400 Cavalcade LXE
Raising seat on x games bmx bike
A good bike shop will sell you a new seat post. You should take the bike with you as the posts come in different diameters. They can also cut it to the proper length for you if you don't have the tools.
Jun 13, 2009 | Cycling
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
