Medion Akoya mini 10 netbook 1210 asks for password to enter bios. I want to reset but never known the present password
  • 27,725 Answers
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased or
When you boot up to the log in screen type in administrator as user if you cant log in During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
Posted on May 21, 2011
I need to reset password on Medion Akoya e1317t netbook?
Use Hirens boot CD ---- Fantastic Freeware tool
1. http://www.hirensbootcd.org/download/
2. http://www.hirensbootcd.org/burning/
3. How-to's ----- http://www.hirensbootcd.org/category/howtos/
Changing the boot order-- http://www.hirensbootcd.org/change-the-boot-order-in-bios/
Resetting Windows Password-- http://www.hirensbootcd.org/resetting-windows-password/
Hope This Helps! I work in the IT field --- Not a big issue I see it all the time --- Good Luck!
Sep 06, 2014 | Computers & Internet
If you are talking about resetting your windows password please check out one of my previous question that I answered this might help. If you have forgotten your password.
http://www.fixya.com/support/t25071622-need_reset_password_medion_akoya_e1317t
This link should help you reset your password
Sep 06, 2014 | Medion Computers & Internet
Factory reset for Medion Akoya P8610
you must restart using HOLDING CTRL OR FN with f2 or esc depend of your mark of computer, they enter to BIOS now go tot reset factory defaulty, and ready.
God bless you
Jun 23, 2013 | Computers & Internet
Forgot password to mini netbook useing windows ce
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://www.tech-faq.com/reset-bios-password.html
hope this helps
Sep 13, 2012 | Computers & Internet
Reset administration password for a dell inspirion 500m
turn on the computer --> press f8 on start up after flashing of the bios screen
it shows advanced start up options from the menu select safe mode
then it shows classic logon screen type username as administrator leave password as empty and press enter
now you can reset the password using user account control panel or using computer management from control panel
May 09, 2012 | Dell (INSPIRION MINI 10) Netbook
I have a mini laptop e1212 medion akoya product with a webcam but i cannot use it ..may be it is installation problem i do not know.i will be very greatful if this problem can be solved.
It will be good to have the PC reset to an earlier set restore date. Now the OS will be reset and if there are errors it will be corrected.
Also please check to see if the drivers are OK in the device manager . If this wont solve you will need to reinstall the OS and the drivers of the PC.
Mar 21, 2011 | Medion AKOYA MINI E1212 COMPATIBLE LAPTOP...
Hp mini 110 reset bios
If the bios don't have password just press F2 when booting, if have password need to open the machine and remove the CMOS battery (the battery is like a coin) for about 10 sec.
Dec 29, 2010 | HP Mini 1000 Netbook
How can i remove the password in the HP MINI 1000 netbook while i did not even know my password it just came out asking a CURRENT PASSWORD? How can i reset the BIOS of HP Mini 1000?
remove cmoc battery from motherboard for a minute then connect it again password will remove
otherwise change bios chip is the only solution
Jul 16, 2009 | HP Mini 1000 Netbook
Computers & Internet Logo
582 people viewed this question
David Payne
David Payne
