I changed the belt on my GE washer. At first everything started, but clicked a lot then the agitator would stop. Then it started again. After it finally went through the spin cycle everything seemed okay until I put in another load of laundry. Everything started briefly, clicked again and then the agitator stopped. For a while the belt kept going then it stopped. The motor sounded like it was trying, but then it tripped the circuit. I tried it again and each time nothing would move and would trip the circuit again. Any help would be appreciated. ----- Robert
  • 4 more comments
  • rbradley3 May 21, 2011
    I'm sorry. I forgot to post that it is a GE top loading washer. The information that I found on the motor is:
    5KH61KW2516S
    9704 MB2
    1/2 HP 1725/1140 RPM
    115V 60 HZ 9.2/7.3 A
    INS CL F 40 C AMB C0783
    Does this help or am I missing some other information?
    Thanks!
    Thanks. I totally missed that. The model number is WJSR2080T6AA
    Not sure. I'll try to take off the belt and reply. Thanks
    Yes, the motor still operates and I'm able to rotate the part that holds the belt in both directions with no problem.
    The tube will move, but not freely. I have to really force it to move.
    Nothing stuck. It just will not move without a lot of effort.
  • Washing Mach... Master
  • 2,605 Answers
Hello Robert, welcome to FixYa.
I will start by saying your post indicates it is a GE washer, however if you could post the complete model number and the approximate age I can speak directly about possible causes/remedies instead of generalizing.
I'll need to clarify the model number before detailing much of course. I'll need to watch for your reply before moving forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on May 21, 2011
  • 3 more comments
  • Mark MacDonald
    Mark MacDonald May 21, 2011
    thank you for the reply, unfortunately the info on the motor is not pertinent to the model of the actual machine.
    The model number should be along the left or right side near the bottom of the machine if it is an older GE top load washer.
    If it is not old (circa 10-15yrs) it may be at the back of the control panel or under the lid. I'll watch for your reply.
    Thanks,
    Macmarkus :)
  • Mark MacDonald
    Thank you that is what I was looking for. I see it is the more modern style GE top load machine.
    Knowing this and factoring in your description, "I tried it again and each time nothing would move and would trip the circuit again"...does the motor operate if you disconnect the belt from the drive pulley ?
  • Mark MacDonald
    O.K.
    This is typically associated with the tub not spinning freely, thus not allowing the motor to operate...too much load on the motor.
    Check to see if the tub will spin freely without resistance in either direction. If not it could simply be an item stuck between the inner and outer basket, i.e. a sock, undergarment, etc.
    I'll stand by for your response.
    Macmarkus :)
  • Mark MacDonald
    Alright. I'm not sure if you know how to remove the agitator and basket, but I'd investigate possible items stuck between the inner and outer tub/basket causing the basket to jam up.
    The agitator should simply pull off with upwards force...careful not to hit yourself when it releases...I have before. Then the drive block will be held in place usually by a 7/16" nut, remove it and the block.
    Next will be the inner basket fastener...usually a large nut that requires a special spanner wrench...but can be done with a large adjustable wrench.
    Once this is off you can pull the inner basket and inspect for garments causing the thing to not want to move.
    Let me know how you make out.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again, sorry for the delay I was having supper. Next to check, careful of the sharp edges underneath, but if you turn the pulley below the transmission (this may require another set of eyes and sometimes a screwdriver through the holes in the drive pulley helps spin it easier) one direction it should agitate and the other should spin the tub. What happens doing that ? You may have a seized tranny...that may be the reason you needed the belt to begin with in hindsight ? Give it a try and let me know.
    Macmarkus :)
GE washer agitation starts normal the progressively slows and then stops agitation. All other modes work fine. Model # unknown. Motor or transmission? Thanx people!!!
Model # located on the back of the control box of top load, just inside of door on front load. Other Op modes ok, problem points to agitator support shaft or the belt drive of the agitator.
Nov 17, 2015 | GE Washing Machines
Where can I find a diagram of a ge whre5260e? I'd like to find the agitator.
When the machine agitates, it stops working. The belt has a lot of tension at this point.
stops working?? does it trip shutdown what
your info is far too sparse to make any definitive view
if the belt and rotors gears {egg gear} has failed
you would hear it grinding
so can you hear the motor running
ie youll hear the water circulation motor pump
usually one motor is used for both
if this is the case and the motor runs then its the gear system thats wrong
check the agitator motor start up capacitor hasnt failed
the info you give isnt good enough
Feb 08, 2015 | GE WHRE5260E Top Load Washer
My daughters GE same model washer will not agitate. Stop agitating after just a few months after being purchased. I believe this is a trait from this type of washer. Perhaps GE needs to recall them all...
Premature failure usually is a reuslt of overloading and/or not enough water. So, there is a rubber drive component that fails and some models have agitator pawls, or dogs that fail. Both are fairly easy to change, and not pricey, except for labor..
Feb 07, 2011 | GE WBSR3140DW Top Load Washer
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
I have a GE washer model# whdrr418e1ww, it stopped agitating. It fills with water and runs through all the cycles fine. during the agitating cyle the motor is running and the belt is moving but the...
Under the agitator is a drive block made of plastic. It is built to receive the transmission shaft spline. With age the drive block wears smooth and the shaft can no longer cause agitation. Yank off the agitator and the drive block is right there. A new bolt comes with the drive block or sometimes called a drive bell.ee76b0d.jpgf93262b.jpg
Aug 18, 2010 | GE 3.5 Cu. Ft. 18-Cycle King-Size Capacity...
GE Model wwsr3090t6aa Agitator problem
You probably have burning belt LOL.
Can you turn the agitator by hand at all?
If no, look for anything that may have gotten wedged under the agitator causing it to lock up.
If you can turn it a little. you most likely have a worn stretched belt or tensioner spring.
The only solution for that is to replace the belt or tensioner spring.
Dec 06, 2008 | Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washer Problems
I have the same problem with my GE washer (GJXRP080B2WW). We started the washer before going out and when we came back home. The cycle finished and the cloths were clean but all wet! I then tried again and it did fill water and drain but didn't agitate or spin. I checked the lid switcher, the timer and the agitator which are fine. However, the motor belt doesn't move and it seems the motor doesn't work when power was on. There are a lot of wires connected to the motor and I don't know which one to check to be sure power goes to the motor. Could you please help me? Thanks.
BTW, I didn't find any Reset button or the start capacity...
Dec 18, 2007 | GE WJRR4170E Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
