Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawn mower starts good and soon after starts to smoke heavy then stalls cleaned carb checked needle and seat good checked coil good.
  • 10,319 Answers
Adjust the valves to .008 to perform like new again
Posted on May 21, 2011
When i started up my rawn mower it was smoking very heavy checked the oil and found gas mixed with the oil what causes this
you will need to rebuild the carburetor. clean it really good with carburetor cleaner. install a new kit. be sure to replace the needle and seat. drain and change oil. it will still smoke for a little bit to burn off the oil that is in the muffler. it will clear up. as for the numbers clean the outside of the carburetor and write down all the numbers you find. your local parts store will be able to get it from there.
Apr 07, 2016 | Garden
I have a 38 inch ride on 1997 model 71193 just changed oil oil is at proper level it pushes heavy smoke at high rpm it is pushing oil into bottom of air cleaner through port , is this the pcv? Do I need...
Was it smoking before you changed oil? Did it start as soon as you changed the oil or did it start smoking a few days later?
Check the oil level again... Ethanol gas kills these Needle valves in the carburetor allowing gas to run through the carb, into the cylinders and down to the Crankcase.
Oct 25, 2013 | Toro Lawn Mower With Toro Power Tools
18.5 briggs stratton runs a few seconds then starts smokeing then stops smokeing then starts smokeing again
check the oil level see if its overfilled and smalls like gas if so the needle valve in the carb is not seating replace the needle and seat add a **** off to the fuel line and change the oil gas leaks passed the needle valve overfills the carb and drains into the cylinder and crank case run the carb out of gas by shutting off the fuel line and run it til it stalls out every time your done using it
Aug 30, 2012 | Garden
Carb full of gas
sounds like the float is sticking inside the carberator might need new needle and seat as wel as a float check to see if float is gas logged
Jul 06, 2012 | Parks Optical 13.5hp Briggs And Stratton...
Toro lawnmower will not start because it floods out
sounds like the needle valve in the carb is not seating take it apart clean it and change the needle and seat inside the carb
Jun 27, 2012 | Toro Power Lawn Mower
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil and white smoke out through exhaust?
smell the oil if it smells like gas change the needle and seat inn the carb and change the oil the valve in the carb doesn't seat and the gas drains into the oil
May 24, 2012 | Yard Machines Garden
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
LT 1000 flooding gas out muffler and stalls, then pours in carb.
Check your oil. Does it smell like gas? If so, don't run it even if you could. You will fry your engine. The float needle and seat in the carb are leaking. In other words, the float needle is not shutting off the gas when the bowl is full. You need to have them replaced.
Jun 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
74 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
