Question about Garden
I have a snapper 11hp mower and the belt keeps falling off when I run the blades. But when I adjust the tentioner then I see smoke from burning rubber. The pulleys all spin freely so what could this be?
  • 125 Answers
SOURCE: snapper comet rubber drive
Get a new drive wheel.
Put mower in neutral.
Stand mower on rear supports.
Remove the four bolts holding the old wheel.
install new wheel.
Posted on Jun 16, 2009
  • 22 Answers
SOURCE: Craftsman 42" Tractor Blade Problem
sounds like either the spindal bearings are shot or maybe the spindal shaft is bent. check for up and down slop at the blades. then turn blades towards each other and check that the heigth lines up. also chec the idler pully to make sure it is not slapping around.
Posted on Aug 14, 2009
  • 138 Answers
SOURCE: broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Posted on Aug 15, 2009
bbreton
  • 437 Answers
SOURCE: shearing of flywheel pin on starting 12 hp snapper
When you the key this time, put the flywheel on first then the key but this time use a little grit between the flywheel and crankshaft. Something like grinding compound. It will keep the flywheel from moving plus make sure you torque down the flywheel nut good.
HTH
Good Day.
Posted on Oct 29, 2009
al_kupchella
  • 843 Answers
SOURCE: how to adjust rubber drive disc on snapper mower
Pages 101, 102 of this may help. http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=aheruJvLlSZk
If that's the wrong manual, try this link http://www.snapper.com/manuals/index.cfm?rd=1
Posted on Mar 23, 2010
Mower blade not engaging
Check your belt. May broke, off, slipping.
Apr 05, 2014 | Snapper Garden
My snapper hydro has no power
check the belt tention for the drive pump
Mar 25, 2012 | Garden
Blade stops rotating under load Honda HRU216M1 (Aust)
sounds like you smoked a belt check your blade tensioner belt, possibly an idler pulley bearing or your belt jumped off pulley, not getting right tension on belt for blade
Nov 11, 2011 | Garden
The blade belt on my yardman yardbug smokes or burning whichever the case may be,why is this?
Either the blades are not moving due to a tight shaft under the mower deck, or a simpler malfunction, hopefully the belt just needs tightened by adjusting the pulleys.
Aug 13, 2010 | Garden
Drive belt falls off mower
You need to inspect the pullies holding the belt, and the bearings that run the pullies. If they are bad they will jump the belt.
Oct 29, 2009 | Garden
I need a drawing of the gear arrangment of a snapper lawn mower model number 3011x6s
Displaying Smooth Clutch Assembly parts for the Snapper 3011X6S 30" 11HP Extra Tough Rear Engine Rider Series 6:
Sep 20, 2009 | Garden
Problem replacing belt on a ols rear engine snapper?
what kind of mower & model # i may be able to help thanks wade
Jun 22, 2009 | Garden
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
