Question about Hobart HL600 Legacy Stand Mixer
Power went out then back on and mixer reads err and 12 in the timer turned breaker off then back on still reads err
  • Hobart Expert
  • 119 Answers
Leave the breaker off for at least one minute then try it. If that doesn't take care of it then you will need to have Hobart come out and check the frequency inverter (drive).
www.hobartservice.com
Posted on Sep 13, 2011
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
4.5 quart. Why doesn't it turn on?
It is not turning on because the power is not getting through the entire circuit. First easy thing to check is the carbon brushes under the black screw caps on the side. If they are worn out just replace them. They are keyed with one corner shaved off so line the key up with the blocker inside the hole where the brush goes. Use a torch to look in there to see it in one corner right at the bottom. You could also remove the back cover and make sure there are no broken wires there, it's not uncommon for one of the bottom wires to break off by the plate they plug on to.
Feb 13, 2016 | KitchenAid Food Mixers
What size circuit breaker circuit breaker
Copy following link to determine correct wire and circuit breaker size:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Be sure to match wire size and breaker amp rating so breaker will trip when heat on wire reaches trip point.
Undersized breaker, or undersized wire are fire hazard.
Maximum 12 boxes per circuit breaker.
Nov 23, 2012 | Food Mixers
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer walked off the counter and bent the shell housing... Mixer works but is squeeking and has loose nuts inside...How do i open it up?
Customer Service Information
Before Calling for Assistance
Please read before calling:
• The mixer may warm up during
use. Under heavy loads with
extended mixing time periods, the
top of the unit may feel warm to
the touch. This is normal.
• The mixer may emit an odor,
especially when new. This is
common with electric motors.
• If the flat beater hits the bowl,
stop the mixer. See page 10 for
more information.
If your mixer should
malfunction or fail to operate,
please check the following:
• Is the mixer plugged in?
• Is the fuse in the circuit to the
mixer in working order? If you
have a circuit breaker box, be
sure the circuit is closed.
• Turn the mixer off for 10 to 15
seconds, then turn the mixer
back on.
• If the problem is not due to one of
the items mentioned above, see
Customer Service Information.
• DO NOT return the mixer to the
retailer as they do not provide
service.
If you have a question about your mixer, call our toll-free customer service
number. Before calling, please note the model, type, and series numbers
and fill in that information below. These numbers can be found on the
bottom of your mixer. This information will help us answer your question
much more quickly.
MODEL:___________________ TYPE :___________________ SERIES: __________________
CUSTOMER SERVICE NUMBERS
In the U.S. 1-800-851-8900
In Canada 1-800-267-2826
hamiltonbeach.com
hamiltonbeach.ca
KEEP THESE NUMBERS FOR FUTURE REFERENCE
Sep 17, 2010 | Hamilton Beach 400 Watts 63220 Stand Mixer
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
Hobart H600 Double Pole Breaker
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
May 31, 2009 | Hobart H600 Stand Mixer
Timmer assembly
this a 115 volt single phase timer you can buy the timer at hobart.com or jump the timer by jumping the red and brown wires but the timer will not work if you want the phone # of hobart tell fixYa to email me and i will leave the number they are located in jackson hieghts N.Y
Oct 30, 2008 | Hobart D300-6036 Mixer
Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Jun 20, 2008 | Hobart A200 Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
