Question about Dell 1320c Laser Printer
My del 1320c color laser printer keeps jamming. I have looked at the underside of the printer and I believe the roller is jamming. Help.
  • 1,555 Answers
Can you kindly first disconnect your printer from power and use a vaccum cleaner and blow the printer from the side where the paper intake tray is established. Then give a print out on a thick paper while selecting card stock in the paper type in printers property. This will take care of the jams. In case you live in a humid country where humidity is high then kindly make sure that papers are shuffled before keeping in the tray.
Posted on May 21, 2011
I have a Dell 1320c printer and there is a part that I need to replace but I have n idea what it is called. When you open the front it is on the very top. It is the last roller the paper goes through
the last set of rollers are fuser rollers you have a heat roller and a pressure roller the pressure roller is made of rubber and the heat roller is made of aluminium.from the your question im guessing that the paper is wrapped around the heat roller. if this roller has scratches in the serface it does need replacingalso if the pressure roller is damaged it also will cause a papetr jam.
also you should check that all of the picker fingers are all in place and clean.
I’m happy to help further over the phone at https://www.6ya.com/expert/geoffrey_a52be3eb7822ef96
Feb 12, 2015 | Dell 1320c Laser Printer
How do i get service for a Dell color Laser Printer 1320c
Pcmacprinter.guru We can help with all printers and
Parts needed.
Oct 19, 2014 | Dell Office Equipment & Supplies
I have the Dell 1320C and everytime i print there is a blue line that goes from top to bottom on the left side of the page. how do i fix?
replacement of the drum would be required. You could first check to see if you have anything stuck to or jammed between the drum roller and the rest of the unit.
Jul 29, 2011 | Dell 1320c Laser Printer
Dell 1320c print spool issues
Today I installed my new printer Dell Color Laser Printer 1320c. I cannot print as documents sent to spooler. I tried reinstalling. o good. I disabled spooler...no good. I'm a technophobic with little spare time, running own business and cannot print the documentation I need. Any help out there?
Jul 02, 2011 | Dell 1320c Laser Printer
Have a dell 1110 printer that will not pick up paper. Roller has been cleaned of dust with alcohol pad
You may want to try looking at the rollers through the back of the printer when it tries picking up paper. Look and try to see if the roller assembly is even turning the rollers. If that works fine and you can see the rollers trying to push the paper into the paper path, there may be something blocking the paper from going through. Pull the paper tray out and inspect it for any damaged or missing parts. Then look on the underside of the printer where the paper path begins. Chances are there is just some jammed paper keeping any more pages from going through. If the rollers have been cleaned they could just be worn out and need replacing. Contact Dell tech support if you can't fix it yourself or need any parts.
May 20, 2011 | Dell 1110 Laser Printer
Paper is jammed inside and I can't get it out, I can't see it to pull it. When I turned the printer on again to see if it would run the paper through it started smoking.
See if there's a back cover that you can open to get to the back side of the print assembly rollers so that you can remove the paper. Also, you may remove the toner and try taking out the rollers assembly and get to the paper jam.
Hope this was useful. If it was, please give it a Thumbs Up. Thank you.
Jan 19, 2011 | Dell 1320c Laser Printer
On my 2 year old Dell 1320c the black is not dark but only gray. I put in a new toner but that did not help. Other colors seem to be good. How do I fix it?
You might try restoring the defaults on the printer. Double-click the Status Monitor Console icon on the Windows task bar. The Printer Selection window opens. In the Printer Selection window, click Dell Color Laser 1320c.
The Dell Color Laser 1320c Launcher opens.
Click the Tool Box icon. The Tool Box opens. Click the Printer Maintenance tab. In the upper left window, select Reset Defaults. Click Start. The Password window appears. If you have not set a password for the printer, click OK. Otherwise, enter your password and click OK.
Oct 21, 2010 | Dell 1320c Laser Printer
How to clear flashing exclamation error light
taker out the toner/cartridge, the paper and then unplug the power.. Also open the printer cover and look for any paper which could be jammed.. take out the paper as well ..
Ensure that all the papers are properly stacked in each tray.
Also fan out the paper before loading in the printer.
After about 10 seconds, plug the power back in and reinsert the ink/toner and paper.
Sep 07, 2010 | Dell 1320c Laser Printer
Lost CD for Dell Laser Printer 1320c installation setup
Check this link and click on the "Download Now" button. The driver is 8MB.
http://www.soft-go.com/download_driver/Dell-Color-Laser-1320C_137.html
Have a great day!
May 05, 2009 | Dell Office Equipment & Supplies
Dell 1320C
On page 30 of the 1320c manual it says this signifies the coming end of the PHD (print head device). I cannot find a part number or reference to the PHD on the Dell web site pages connected with this printer
Jan 30, 2009 | Dell 1320c Laser Printer
Dell 1320c Laser Printer Logo
100 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
