Question about Pentair 2 hp Challenger Pump
Hi, I have this Challenger 2HP pump out on the bench but can not separate the pump housing and impeller from the motor. I've removed the 3/8 bolt from the center of the impeller. And the band is off the pump housing.
  • 3,740 Answers
Take a look at this picture:
http://www.poolcenter.com/parts_pumps_pacfab_challenger_highflow.htm
Make sure you remove the mounting screws item 15 (2 ea) and item 9 (4 ea)
There are also 3 screws 120 deg apart item 12. Screw holes can be seen on item 2.
The impeller has a Locking screw item 10 that if it is not removed makes it impossible to remove the impeller.
Thanks for choosing FixYa,
Kelly
Posted on May 21, 2011
Pentair challenger 2HP pump start capacitor
check the bump on back of motor remove cover take picture of wires then get new one from electrical supply store
Jun 24, 2014 | Pentair 2 hp Challenger Pump
Need to replace old pump.
easy both of them are junk. get a (sta-rite max e click on it) a 1.5 hp should do just fine. the 2hp is to run your spa and not economical to do unless you you have two pumps one for the pool and one for the spa.. if you have a 2 story house with solar you will need a 2hp
used pumps can be tricky so search for your local pool pump repair guy and see if he could build you one, this will save you money and be handy if you need repairs in the future ! ask him how to take care of your pump !
jay the pool pump repair guy longwood Florida
Sep 05, 2012 | Pentair 2 hp Challenger Pump
Proline 2hp pump not getting water pressure
make sure top seal ok if ok check intake union make sure tight check impeller for debris
Jun 30, 2012 | Pentair 2hp 230v Ur Mh Challenger High...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
I have a Pentair 2.0 pump that I am trying to remove from the impellar. The shaft turns allowing me to turn the pump part itself but I can not pull it loose from the rest of the housing. How exactly do I...
The impeller is threaded onto the motor shaft. On 2hp motors and above, there is usually a screw with reverse threads to help secure impeller to shaft. To remove impeller, first remove screw(reverse threads) Next, remove back cover off motor. The shaft either has a slot for a screwdriver or flats for a wrench. Hold shaft and unscrew impeller.
Aug 21, 2011 | Pentair One - Speed 1hp 115v Dynamo Pump...
Replace pool motor
First you'll need to take the outer 6 bolts off the pump housing and that will allow you to remove the impeller and impeller housing with the motor. Then you can remove all the impeller parts and get to the bolts that hold your motor to the housing....
When you get the impeller and the housing free, check to see if your motor will turn... alot of times the motors get jammed because the pump sucks debris and jams in the impeller.... you may be able to still use your motor...worth a try...
K
Aug 05, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Making humming noise and trips breaker. not sure what happened
MOTOR I SHUTING DOWN DO TO OVERHEATING PROTECTION MOST LIKELY SOMETHING IN IMPELLER CHECK TO MAKE SURE SHAFT CAN TURN WITH PU OFF TAKE PLIERS AND TURN SHAFT AND THEN START
Jun 09, 2009 | Pentair 2hp 230v Ur Mh Challenger High...
How do i tear down impellar housing on ao smith 2hp bn50 pool motor?
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
May 16, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Disassemble pentair challenger pool pump
remove the 3 screws on the front with 1/4 inch nut driver remove the diffuser and mounting plate remove cap covering the bolt head on the back of the motor hold the motor shaft with an ajustable wrench or vicegrips turn the impeller counter clockwise it should only be hand tight unscrew the impeller
Apr 16, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Pentair 2 hp Challenger Pump Logo
168 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
