Question about RCA RTD160 System
The power board bowled up because it was 110 voltage and they plugged it in a 220 voltage power and the system is not working again. I am very worried not knowing what to do with my system.hope you will help me get my machine back thanks,
I have the problem with power control no vc3845b how can get this because i have tried to find the same no but i dint get it so how can i get equivalent of this product thanx
Posted on Aug 02, 2012
SOURCE:
Blown fuse again and again, mistakenly plug in 220 then blew the fuse because its power rating is 110
OK now so you plugged it into 220 when it is supposed to work with 110 and after you replace the fuse it still blows again this may be because of the high voltage the voltage could have caused the insulation on the wire in the transformer to burn off resulting in a short thus lowering its resistance and increasing current flow which will cause the fuse to blow over and over again no matter how many times you replace it . so my advice is to not plug it on again as it poses a risk of fire
Aug 13, 2016 | Televison & Video
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
I live in China and brought a Keurig back with me from America. I went to plug it in a standard converter. The machine turned on for a few seconds and then shut off. I have tried turning it on again. It...
My guess is that the heater in it draws too much power for a converter. US is 110 volts, is China 220 volts? That is a step up transformer and they are not reliable.
yes 220 volts
voltage in china Google Search
Okay, a Keurig draws 1500 watts of power.
HOW MUCH POWER DOES KEURIG BREWER USE
I wonder if you bought a step DOWN transformer, 220 to 110? That would light up for a second until the heater element kicked in.
Does you look like this
Goldsource STU 2000 Step Up Down Voltage Transformer Converter AC 110 220...
or this
ELC 2000 2000 Watt Voltage Converter Transformer Step Up Down 110V 220V...
The other consideration is that the Chinese are masters of copying, so they must make a Keurig clone.
The downside is that the Chinese make rubbish electronics like your transformer.
Feb 06, 2018 | Keurig Coffee Makers & Espresso Machines
What is the polarity and voltage setting for the hot water on demand system
Well if you buy a 220 system it will be 220 volts.
All the bigger systems like for whole house will be 220.
some smaller under sink models will be 110.
There is no polarity since it is AC. If you find something that says polarity on a on demand water heater then somebody at the factory is smoking something.
110 has 3 wires. all tests need done with a multimeter on the AC setting.
Black wire will be 110 volts AC, White wire is neutral and green wire is ground.
220 system also has 3 wires. Colors can vary a bit here but usually it goes like this.
Red wire is 110 AC - Black wire is 110 AC and white wire is Neutral or ground.
Test to ground they read 110 Volts AC test to each other they read 220 AC because they are out of Phase to each other.
PLEASE note. Always get a certified electrician to work on these units. If you feel you are just as good as any electrician, please make sure you have a family member nearby with a phone that can dial 911. 110AC can kill you and 220 AC can kill you faster and deader.
To know whether any particular unit is 110 or 220 we would have to have the model number to look it up. Some can be either and in this case the only way to know is to take the junction box apart. If it is just plugging into a regular wall outlet then it is 110. If it looks like a special plug or like a dryer plug then it is 220.
Hope that helps. Have a great weekend.
Apr 16, 2010 | Coleman Hot Water On Demand
Sylvania GNET28001SO Meso 8.9" Netbook PC (1.6 GHz Intel Atom
If you are attempting to connect your laptop between 110 and 220 volt power outlets, you may be able to do so already, take a look at your power cord's transformer (brick) and read the input voltage. If you only can use 110 volt AC Input Voltage should read 115VAC. If you can do both, then it should read 110-225VAC.
If your power brick supports 220, then all you will likely need is a plug adaptor, found at many electronics store. If not, you wil need to stop in at a computer store or an import store and get an international transformer, which are set up to convert many different country plugs and many common voltages.
Good Luck!
May 06, 2009 | Sylvania Meso GNET28001SO Notebook
The power supply of my pioner dvd was burn
Hi
check all semiconductor in the power board and look for a shorted and open parts! then replaced the defective parts.
Thanks!
Dec 05, 2008 | Televison & Video
Hcd bc150 main power
Please check Input Voltage 110 ~ 240 volts AC at rear or bottm side of unit. If same is written there, its Auto Voltage Operatable and can be use on 220Volts.
Aug 31, 2008 | Sony DAV-BC150 System
BOSE DOESNT TURN ON AFTER PLUGGING TO A 220-240V PLUG AND ITS ONLY 120 VOLTS
It sounds like you hav blown a fuse. Hopefully just a fuse, connecting a 110 to a 240 will hurt.
Most equipment survives short term high voltage but sometimes it just can't take it.
if it's not the fuse then it's very likely damaged the power supply which will require the expert help of a technician..
good luck !
Ps the 321 is a very nice bit of kit..
Mar 30, 2017 | Bose (321GS) System
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
RCA RTD160 System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
