Question about Toshiba A15-S1292 Notebook
Keyboard keys not.
I have keybord with the following keys not working:
Esc, Tab, Caps Lock, Fn, 1, a,
q, z.
I've tried another keyboard, Same problem. Checked connections, all are good. I need help please.
  • ivanmonteiro Oct 09, 2008
    same problem... i didnt open the notebook for two months while i was buying a new cooler for it... when i used it again, some keys are not working( F8, f, BACKSPACE)
  • theorist2 Feb 11, 2009
    I have the same problem with the exact same keys (esc, f1, `, 1, tab, q, capslock, a, and z) on our 4 year old toshiba satellite M35x-s109.
    It's helpful to hear that replacing the keyboard didn't help you. I was going to try that next.
    Intermittently, these keys on the left end of the keyboard don't respond. I first noticed the problem running in Windows XP, especially upon starting up or waking from sleep or hibernation. I tried running from a couple different linux livecd's but found the same problem intermittently, especially upon startup. I then found that the problem occured within bios setup intermittently. I reset the bios to default settings; didn't help. I flashed the bios from v1.90 to the just released v2.00, no help. Back to v1.90, didn't help. I removed the keycaps and found a little typical dirt, but nothing unusal. Vacuumed, didn't help. I ran memory tests, came up good. I swapped the memory, just in case, and reran memtest, still came up good. Still get intermittent unresponsive keys upon cold boot.
    I thought it must be a bad keyboard or connection, but your post suggests it may be something else I haven't imagined. I haven't tried a USB keyboard.
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
My caps wont turn off
Try this. Press: Start>Accessories>Accessibility>On Screen keyboard. Try turning it off from there. If that doesn't work:
1. Choose Start'Settings'Control Panel and double-click Regional and Language Options.
2. In the Languages tab, click the Details button.
3. In the Settings tab, you should see a button called Key Settings. It may be grayed out. If it is, click the Add button and add another keyboard layout (it doesn't matter which one). Press OK.
4. Back in the Settings tab, click to make sure your original keyboard is highlighted and press the Key Settings button.
5. Now under To turn off Caps Lock, click the radio button next to Press the Shift key. Click OK.
6. Click OK twice more to exit the other two dialog boxes.
Jan 13, 2011 | HP Computers & Internet
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
ADESSO Keybord AKB-210
clean ur keyboard keys by removing from keyboard
May 21, 2009 | Adesso EKB-2100W c66656 Keyboard
Some buttons in my keyboard system are not functioning anymore
PLease reinstall the Keyboard Driver . Download from the official site go for Support and download
Apr 02, 2009 | ASUS m6n Notebook
I live in London E8 2NH and got a problem with the keyboard on my laptop Fujitsu-Siemens Amilo Pro V 2040. I strungle find a local service/repair shop.
install keybord driver properly.
if u have keybord hardware pro.then u must have to go shop.
also check tab.num lock shift caps lock not jamming.
all key check .
Oct 11, 2008 | Fujitsu Siemens Computers & Internet
Laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
Oct 08, 2008 | Dell INSPIRON 6000 CENTRINO...
Compaq Presario v2405us Laptop keyboard help
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
Jan 07, 2008 | Compaq Keyboard
My new logitech keybord
The "A" signifies it as a capital key
The 1 signifies it as a number key
Being a cheaper model it does not have that feature.
Did it come with an installation disk?
Maybe when you install it the cap lock and number lock will be on the computer screen in the system tray.
Some do that.
If not you may want to take it back and get a more expensive one. One, that has the features you like.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
Toshiba A15-S1292 Notebook Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
