Question about Microsoft Xbox 360 Console
My xbox turns but the image docent pop out - Microsoft Xbox 360 Console
    Scholar:
  • 53 Answers
To reset Xbox 360 console display settings
  1. If there is a disc in the console, remove it.
  2. Turn off the console.
  3. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller.
  4. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
  5. The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
Posted on May 21, 2011
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Auto choke(90 mitsubishi mirage)
It is best to have your vehicle checked out by a good shop. There are many things that could be wrong with your vehicle, from a fuse, to the ignition switch (not the ignition lock cylinder where your key goes into) to a wire that someone hooked an aftermarket stereo/alarm system into.
Nov 03, 2013 | Mitsubishi Cars & Trucks
My Samsung Wave keeps restarting from time to time? Any solution for this problem? Thank you!
Have u tried a cold reboot. That when u have the phone on and Take the battery out of the phone wait it on It set hidden setting on the phone and stop many Error. Pop battery back in the turn on the phone. If that docent work u may have to sent it sent off for repair to To get it reflashed. R the phone have sum water damage
Jan 16, 2011 | Samsung Wave S8500 Smartphone
One ring of death e 68
This is the display chip overheating and to stop this you need to use a good guide that will show you how with household items or you can send it in to get it fixed. Try this Xbox 360 repair guide first, I used it to fix my son's 3 rings of death on his xbox...no problem. good luck
Jun 10, 2010 | Microsoft Xbox 360 Console
My son was playing on his XBox. Turned it off. When he came back it powered up (green light) but no image on the TV so we moved it to another TV still no image on the screen. We plugged and unplugged...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Feb 23, 2010 | Microsoft Xbox 360 Console
100% burns xbox360 game but says play dvd when i put in xbox
Chances are what you are copying is COPYRIGHTED and the electronic protection will prevent you making a USABLE copy that the Xbox will run.
Nov 05, 2009 | Sony Computers & Internet
No image on xbox
Whenever you need help with Xbox 360 or Xbox 360 accessories problems, check out Xbox Customer Support
The answer is quite long, so here's a link.
And if that doesn't help, try contacting Microsoft directly.
Hope this helps!
May 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 comes on dashboard pops up but wont go to the game
If you have uploaded the updates, this happens all the time. you must go to "my xbox" option and there will be a disc there. Hit "A" and it will play the disc.
Feb 24, 2009 | Microsoft Xbox 360 Console
Xbox 360 turns on but no image comes up on my tv
Check if you turned on the HD or not.. if your TV isnt HD then it wont show anything but the 360 will turn on still
Dec 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
