Question about Garden
Need fuel line diagram for troy bilt string trimmer,model tb75ss, 31cc
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
  • 376 Answers
SOURCE: I need a diagram to adjust/level the Deck
The adjustment is on the left rear deck hanger. Loosen the 1/2 lock bolt in the center of the large nut, then turn the large nut with a adjustable wrench or socket, if you have one that big, clockwise or counterclockwise to raise or lower that side to equal the right side height.
Posted on Jun 05, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
Troy built trimmer fuel lines
normally the one nearest to fuel pump /primeer bulb is the inlet and the lower one is return
WHY can't you just connect hose to one and pump primer bulb to see what direction it goes ?
Jul 28, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Whats the gap on the spark plug on troy bilt tb20cs
Hello, Johnny -
The correct gap is .020" (0.5mm).
Link to specification page in owner's manual attached.
Troy Bilt TB20CS Operator Manual Specifications
Mar 06, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
281 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
