Question about Symbol LS 4000i Handheld
After scanning a bar code I need it to enter and go to next row in excel
    New Friend:
  • 3 Answers
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Posted on Jan 30, 2013
    Guru:
  • 1,833 Answers
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
Posted on May 22, 2011
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit &lt;Enter&gt;? Thanks, -john
YOUR DONE !
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
Tip
How can I create a Barcode for Free in Microsoft Excel?
<p>Placing barcode equipment or other things makes it easier to keep track of them. Instead of entering a long number, a quick scan with a bar code reader eliminates keystrokes. There are many different types of barcodes. The most famous is the Product Code or UPC Universal, in almost all items sold at retail in the United States. The UPC format only supports encryption of the songs. Other formats such as Code 39 (also known as Code 3 of 9) support letters and numbers. <br /> <p><br /> <p>1. Find a free TrueType font to the desired shape of the bar code. For example, the Code bar code format is 39 different TrueType font packages available free. Use an Internet search engine and type "Code 39 TrueType fonts" available in a free font found. Some specialized formats may not be available for free as a result of copyright or other restrictions. <br /> <p><br /> <p>2. On your Windows PC, select the Start menu and click Control Panel. Within the Control Panel, click Switch to Classic View "and appearance of the panel. Find the" Fonts "icon and double click to open it. On the File menu, select" Install New Font. "This opens a menu dialog asking you to change the font to install. Navigate to the folder that contains the downloaded TrueType font file. Select the font and click OK when prompted to install it. The source of new bar code will be available in Excel. <br /> <p><br /> <p>3. Start Excel and enter "98765" in cell A1. This value is converted to a bar. <br /> <p><br /> <p>4. In cell B1, type the following formula: "= CONCATENATE ("*", "*")" A1 and press enter. The result should be "* 98765 *". Code 39 format requires an asterisk at the beginning and end of the text to be encrypted. Bar code format other will have different rules. <br /> <p><br /> <p>5. Change the font in cell A1, choosing a different font from the drop-down menu at the top of the screen in Excel. Under the menu "Home", scroll down to "three of the nine free" source and select it. The text in the cell will now appear as a barcode. Increase font with a minimum of 28 points, so a scanner can pick up the scanning needs. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Nov 02, 2010 | Symbol LS2208 Handheld
I am trying to automatically generate serial numbers in a excel spreadsheet. I have three columns: column A is a date code under the YWW format, column B is the first serial number 00001, and column C is...
Hi JK,
We have to use the combination of dynamic list and indirect() function.
and offcourse countif() and if().
If you need the solution from me, Please send me the sample sheet on ali_zulfikar@yahoo.com so that I can send you the solution sheet.
Zulfikar Ali
Apr 06, 2010 | Microsoft Office Excel 2003 for PC
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
Scanner displays on a same row in excel how do I get it to automatically move the curser to the next line on my second code scan
If you would like the scanner to drop down to the next line scan the barcodes Scan Options, Data Suffix, Enter from the Quick Start Guide that should have come with the scanner. If you do not have the QRG then download the Product Reference Guide from this link:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=134926365&stateId=0%200%2014579837
The barcodes are on Adobe pages 222 and 223 of 342 in this manual.
Oct 15, 2009 | Symbol LS2208 Handheld
Automatic RETURN/ENTER ...
I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
http://www.intermeccorp.com/pdf/2106setup.pdf
May 13, 2008 | Symbol Hotshot LS2106 Handheld
Ms excel fomulas
dear monalinda you have to enter formula in formula bar with = sign and select the coloumn & rows
Sep 24, 2007 | Microsoft Office Standard for PC
Symbol LS 4000i Handheld Logo
2,242 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
