Question about Canon CLC 1180 Copier
LA COPIADORA SIRVE PERO CUANDO MANDO A IMPRIMIR UN ARCHIVO LA HOJA ME SACA EN BLANCO
5 Suggested Answers
  • 92 Answers
SOURCE: en la copiadora aparece la clave de error EOOO y no la se quitar
tens um problema com a unidade fusora chama um tecnico da canon
Posted on Dec 22, 2008
jalamb
  • 103 Answers
SOURCE: el mimo error 220
Scanner Lamp Or Compositive Power Supplys Problem.
Change The Lamp if the problem Continive change or repair The Compositive power supply
Posted on Sep 22, 2009
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
SOURCE: como puedo instalar la impresora
hola necesito ayuda para instalas una multifional canon mf5750 no tengo el disco
Posted on Oct 29, 2012
Tengo un telefono fax panasonic kxft67 cuando trato de hacer una copia la hoja sale en blanco y tambien cuando me llega un fax su manual dice que es impresion termica que puedo hacer
Thermal fax printers need special thermal paper, and it has to be installed in the proper way, since only one side will print.
Impresoras de fax termicas necesitan papel termico especial, y tiene que ser instalado en la forma correcta, ya que se imprimira un solo lado.
(not sure if Google translated that correctly!)
Dec 17, 2013 | Office Equipment & Supplies
Impresora lexmark e352dn imprime una hoja seguida de una hoja blanco
Por favor, intente comprobar la configuración del procesador de texto que está usando antes de imprimir. Compruebe el número de páginas que va a imprimir. También puede hacer esto para ver haciendo clic en la vista preliminar, si hay una página adicional, compruebe la configuración de su procesador de textos de nuevo.
Para obtener asistencia adicional, p?ngase en contacto con asistencia t?cnica de Lexmark..
Jan 13, 2011 | Lexmark Lemark E352DN Laser Printer
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
Mi 95 civic se ahoga en gas y no quiere prender
revisa si las bujias estan tirando la chispa con un "spark tester" o quita una bujia y dejala conectada al alambre, luego pon a alguien mas a qe le de marcha sin prender el carro mientras tu ponle atencion a la bujia, fijate si tira chispa haz lo mismo de una por una(solo de una a la vez, saca una y regresala cuando ya revisaste si tira la chispa) si ninguna tira chispa entonses es tu distribuidor, te recomiendo el "spark tester" por que ba entre el alambre y la bujia y si la bujia no sirve en la bujia no bas a tener chispa pero en el "Spark tester" si. si si es el distribuidor revisa la cubierta y la pastilla pero a ese punto es mejor cambiar todo el distribuidor. espero que esto te ayude. o y recuerda lo principal para que ensienda Gas, Aire y chispa revisa esos tres si todos estan vien va ha prender.
Dec 24, 2009 | 1995 Honda Civic
No puedo imprimir, me aparece error, la opcion de tintas me parpadea y aparece una E encopy menu
la foto copiadora funciona muy bien,pero cuando voy a imprimir ,sale el papel en blanco.
Jan 30, 2009 | HP Deskjet F4140 All-In-One InkJet Printer
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Call for service CD4 en estudio 650
CD4 indicates full toner bag, need to be disposed...
Mar 25, 2008 | Toshiba E-STUDIO 650 Copier
Canon CLC 1180 Copier Logo
old marine
old marine
