Question about Acer Aspire™ T180 PC Desktop
Please help with computer sound problems
Wen i do an audio manage speaker test I can hear sound from speakers. When I am online or even on Windows Media Player I can't hear ANYTHING!!! I don't have a user guide to this computer and I just can't figure it out. I'm not the best at computers and this is driving me nuts!! Please help. I have and Acer Aspire T180. (AST180-UA381B)
  • limi63 Aug 19, 2008
    same exact problem and i dont have sounds and devices icon
    Guru:
  • 1,342 Answers
Click Here for Acer Support. If you have installed Vista SP1 you will need to install a patch for your audio driver.
Posted on Aug 19, 2008
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
Speaker Logitech S-0264B not working with windows xp
if your computer came with a motherboard disc the sound drivers could be on it
if you dont have a motherboard disk you will need to download the sound drivers
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Mar 13, 2012 | Logitech X-240 Computer Speakers
With my speakers all i have to do useually is plug them in and away i go, but now for some reasonm there not working and not showing up in my controll panell as even beein plugged in, but they will work...
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program and test for a virus then
yellow? means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 10, 2010 | Labtec Pulse 375 Computer Speakers
We hooked them up to a Dell computer, but there is no sound. We checked the audio drivers and they are all working properly. What can be the problem and possible solution?
You can try to plug in an external headphone to see if the issue is with your sound card, if external headphone works, obviously the speaker is faulty but if same problem persist. Check if your using an expansion sound card (usually for gaming computers) and make sure it was set primary sound device on BIOS and the integrated Audio is disabled. On windows you can check the sound settings on playback make sure that primary Audio Device is Set to default and no Hdmi Sound Audio is connected Hope this can help you!
Dec 07, 2010 | Dell A215 Computer Speakers
I can only hear a faint sound from the speakers even when all the volumes are turned up. Where can I go to look for the problem?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 12, 2010 | Logitech SoundMan S-20 Computer Speakers
My laptop's audio has stopped working, and the audio area says that the speaker is working and the sound is on, but nothing plays, not even the test tone. I think it is a driver issue. The speakers are...
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
or
hope this helps
Nov 11, 2010 | Computers & Internet
No webcam sound
The problem is probably in their set up, unless your speakers have a problem - you do have speakers?
Your webcam has no bearing on their broadcast or audio - in fact you can still see and hear other contacts even if you have no webcam installed yourself.
Check your speakers
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
If you have a desktop and no speakers fitted buy, a set of headphones for your chats
Jul 28, 2010 | A4tech PK5
Sound is not coming from attached speakers I have window xp and ''zoltrixound'' speakers
There can be more than one reason, why the computer can’t play any sounds. These are discussed below:
So, where do you start, when you can’t hear any sounds from your computer?
Before we start with the solutions, did you try the simplest solution first? Reboot or restart the computer. The sounds may just work after a reboot.
Can you hear the Windows startup sounds from the computer? If you can hear the Windows startup sounds, the sound card is working fine. If you can’t hear any startup sounds, enable the System Sounds in the Control Panel, if they are disabled. If you aren’t able to enable the system sounds and they are grayed out, you may need to install the sound driver.
Are you trying to play an audio CD, and not getting any sound? If you can hear the System Sounds, but can’t hear anything from the audio CD, even though your audio player software tells that it’s playing the disc, the problem is most likely with the digital cable that goes from the CD/DVD driver to the sound card (or to the motherboard).
Are the speakers connected to the proper sound port / jack, at the back of the computer? Are they powered ON? External speakers generally have a separate power adapter, which plugs into the wall socket or any other power source. Is the speaker volume control, set to a comfortable level? If not, turn it to the middle position.
If in doubt, test your speakers by connecting them to another sound device like CD/DVD player or a radio/tape player, or any sound source. If you can hear sounds from the speakers, they are fine.
Check that the speaker pin is connected to the green jack on the back of the computer. Also, check that the sound (check speaker icon in the system tray) isn’t muted. Such a simple thing, which can happen accidentally, can confuse some people when they can’t hear sounds from their computers. This can get overlooked because the speaker icon may be lost between many other icons. Click it and un-mute the sound, if it’s muted.
Note: If you can’t see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click “Sound and Audio Devices” and check the box that says “Place volume icon in the taskbar” and click OK.
Try plugging in a pair of headphones in place of the speakers, to check whether you can hear anything. Play a song or music CD or any sound file, which you may have on the computer. If you don’t have one handy, you can run a command to test your sound:
Click the Start button, and then click Run (or Search, in Windows 7 / Vista). Type the following command and then press the Enter key: dxdiag
Click on the ‘Sound’ tab to see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card and the manufacturer, on a piece of paper.
If you can’t see the name of the sound driver, or aren’t able to hear the sound by using the ‘Test DirectSound’ button, or you get an error, the problem may be with the sound driver. If the sound worked sometime ago and now it isn’t working for some reason, the simplest solution for re-installing the sound driver is to do a System Restore. Restore the system to a date that you know, when your sound worked. Check out the following links for a short tutorial on System Restore
Note: Current documents, files and e-mail are not affected by System Restore. If you get an error like “Restoration Incomplete. Your computer cannot be restored“, undo the last action by selecting “Undo my last restoration”.
Here’s a youtube video on how to restore a system with System Restore: http://www.youtube.com/watch?v=mU5yqvye57E
Here are step-by-step tutorials on System Restore:
For Windows XP: http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/ http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/ http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
If System Restore didn’t help or you get a message that System Restore couldn’t be completed, try the following:
Start the Device Manager (Start -> Run -> devmgmt.msc and hit the Enter key). In Device Manager, Click the + sign next to “Sound, video and game controllers”. See that the sound driver that you noted from dxdiag above, is listed.
Doube-click this sound driver. Device Manager should give a status message that the driver is working fine. If the driver isn’t there or if it shows a yellow exclamation mark, shows under other devices, or gives any other kind of status message, reinstall the driver. In any case, it doesn’t harm to uninstall and reinstall the driver.
From this sound driver properties page, you may also click the Troubleshoot button, to open the Sound Troubleshooter in the Windows Help and Support Center.
You can also visit the following link about tips for fixing common sound problems:
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 02, 2010 | Audio Players & Recorders
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
Acer Aspire™ T180 PC Desktop Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
