Question about Dehumidifiers
When compressor cycles on the circuit breaker kicks off
    Sergeant:
    Champion:
  • 229 Answers
Your compressor has a direct short there is nothing that can be done just replace dehumidifier. If you replace compressor it will exceed cost of new unit. If this helps you please rate me and do a testimonial.
Posted on May 21, 2011
Edison 40 fan starts -then trips breaker (before compressor kicks on)...toast?
Maybe..but what else do you have on the same circuit? Could be overloaded by another appliance. Make sure you unplug all items on the same circuit, then try it again. If it still blows most likely its in the unit, if if runs with no problem, issue is overloaded circui, too many other things on the smae line.
Aug 14, 2014 | Edison 40 Pint Dehumidifier
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
When compresser comes on blows electric breaker
the outlet that you have the dehudifier plugged into has too many items plugged in on the same circuit and when the compressors kicks in it draws more amperage than the breaker load can hold thus popping the breaker either remove some electrical apliances from that circuit load or plug in elsewhere
Sep 14, 2009 | Kenmore 54501 Dehumidifier
Knocks out house curcuit breaker and stopes running. Use to work fine and did for at least two years now kicks out breaker after running for a while. Have moved it to different circuits and still does it....
You will need to put an amp meter on the compressor wires and monitor the reading till it trips the breaker. If the reading exceeds the name plate spec then chances are the compressor is going bad.If the spec is in watts, take your amp reading and multiply it by 120 volts this will give you the wattage of the compressor. For a second opinion take it to repairshop to see if it is worth repairing.
Good Luck!
Aug 15, 2009 | Maytag M7DH65B2A Dehumidifier
FROZE UP NOW IT IS DEAD
UNplug it and let it sit for about 10 to 15 minutes and the built in circuit breaker will reset. The probable cause is the compressor can not start up due to the pressure in the lines so the breaker kicked in to prevent damage
Jun 20, 2009 | Fedders A7DH65B2A Dehumidifier
Whirlpool 50 pint dehumidifier
Lifeguard, there are generally no user accessible safety items in dehumidifiers. You are likely describing the start relay which is used to 'boost' the compressor on starting. Jumping it will not help you. It sounds like the compressor is defective. Economically, there is no justification for servicing these units unless they require refrigerant gas or if the fan motor has seized, something you can readily determine. If you don't hear the compressor hum when it should, there is no service procedure available for these sealed units.
Feb 22, 2008 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
63 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
