Question about DSC Security System Wireless Smoke Detector Ws4916 New
We changed the battery in the smoke detector but it still continues to beep every 90 secs. What do we do?
SOURCE: smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Posted on Jul 17, 2008
  • 17 Answers
SOURCE: just replaced battery in smoke detector and wont stop beeping
take it apart and looked for a silver metal, quipe it and it will be fine.
Posted on Aug 28, 2009
Divalici0us
SOURCE: My alarm and smoke detector keeps beeping a single
Ours keeps chirping even after we replaced the battery. I'm not sure how to fix it.
We are going to try and clean it but if it keeps doing it after that then I guess it means it needs to be replaced, right?
Posted on Jan 20, 2010
  • 3 Answers
SOURCE: GE/ADT DIY system will not accept master code./beeps twice/2 hour
Press the system status button on the top right and the system should announce the error message that is keeping it from accepting the code.
Posted on Apr 26, 2010
  • 5 Answers
SOURCE: How to change the battery in my SCO5RVA smoke and
Not obvious, and th emanual is not too precise about this as you probably know.
What I did on mine: take it off its bracket, flip it over bottoms up. You will see a part of the "rim" curving slightly out, that's the battery cover lid.
It is a very tight fit; to make things relatively easy, rotate the unit with the bottom still facing up until the curved part is on the right of the unit. Make sure there is no (red, if I remember correctly) peg locking the compartment closed, then insert your right thumb in there, and pull out. The battery compartment will eventually slide out part of the way. Remove the battery by pushing them out from below the battery compartment; they are on two separate blades that can be used to push them out.
Shoudl do the trické
Posted on Aug 07, 2010
Firex smoke alarm won't quit beeping?
After you change the battery it will continue to beep every minute or so for about 20 minutes then return to normal operation..
Mar 17, 2017 | Home
Alarm beeping continually faulty detector
What kind of detector. You mean like a smoke detector? Change the battery and see if that helps.
May 02, 2016 | Tablets & eReaders
Is it normal for a garrison smoke detector to have a flashing red light ?
Yes in normal operation the red light should flash intermittently every 30-40 seconds.this lets you know the battery has sufficient power for detecting smoke.when the battery needs replacing the unit should beep/ chirp in singular sound every 60-90.if smoke I'd detected the difference is very obvious as the shrill beep is continuous and much louder.
Feb 19, 2015 | Home
What causes continual beeping
With some smoke detectors, this indicates a low battery. Try putting in a new battery and see whether it stops beeping. If it doesn't add a comment to this question and specify the make and model of your smoke detector.
Oct 06, 2014 | Home
Fire alarm beeping after battery change
you need a good quality fresh battery, cheap or old batteries are not strong enough
Jun 27, 2014 | First Alert Brk / First Alert Smoke...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Every hour my detector beeps and the green lights flashing is it carbon nonoxide or smoke or battery??
If it only beeps once and then pauses, the batteries are suspect. The batteries should be replaced twice each year. I like to change them when we change the clocks back and forth.
I hope that this helps.
asnowman
Hint you can test them with a match (blow it out) and let the smoke rise into the detector. I recommend that this be done at lease once a year.
Hope this helps
asnowman
Apr 17, 2010 | First Alert SA302 Dual System Smoke...
I have 3 of these alaems and 1 keeps beeping
Replace all batteries with the exact make and model listed on device.
Jul 12, 2009 | Kidde 0914 Battery-Operated Ionization...
Smoke alarm/carbon monoxide detector
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
DSC Security System Wireless Smoke Detector Ws4916 New Logo
52 people viewed this question
Top DSC Home Security Experts
yobo007
yobo007
don1956
Level 1 Expert
Terry Weaver
Terry Weaver
Are you a DSC Home Security Expert? Answer questions, earn points and help others
