I am trying to install my printer but I keep getting a message that says "The printer spooler service is not running". Can you please help me fix my problem? Thank you!
spooler service not working
it says the printer spooler is not available
To make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
pls do rate the solution if helped. thanks.
SOURCE: Printer Spooler service!
click on the start button -> run -> type services.msc then hit OK
look for Printer Spooler and make it run
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
That doesnt work for me as soon as i go to install the printer again, the window pops up and says the spooler is not working causing the download to quit before it starts....
I am trying to install my printer but I keep getting a message that says "The printer spooler service is not...
I have gone into Control panel and started the pool spooler and the RPC - but the message still keeps coming up
