Question about Dell Dimension 4600 PC Desktop
My monitor seems to be busted, I dont know if it can be fixed. The problem is that when I turned my computer and monitor on, It said my monitor was on with the green light on the power switch on the monitor. When I turn my computer off, the Monitor light goes orange. Why is the screen pitch black? Help would be appreciated please and thank you :D
  • Dell Master
  • 998 Answers
On most Dell monitors there is a built in diagnostic check. Disconnect the VGA or DVI monitor cable from the computer and power on the monitor. If you see floating color bars then the monitor is not the problem.
Posted on May 21, 2011
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
Faint No Image / Backlight Out on Monitor Westinghouse L2046NV
Open up the unit. You should replace the damaged/bulged caps on it. You should also check the two MOSFETs before the transformers on the inverter section. If that does not do it, there's one SMD fuse beneath the card that normally blows when the MOSFETS fail. You should either replace it r bridge it with solder.
May 30, 2009 | Westinghouse L2046NV Monitor
I have a Dell flatscreen monitor that will not turn on. The power light blinks blue slowly
Hi...there,
It's seems you got a busted backlight inverter. If you still under warranty send it back to Dell for repaired. Happy Holidays!
Dec 18, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Monitor is blinking out
Hi...there,
It's seems you got a busted backlight inverter problems...
Dec 17, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
No lcd light
Hi...there,
It's seems your backlight inverter/ built-in power supply are busted. Need to replaced a new one or repaired it...
Nov 29, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My Dell Monitro goes black about 4 seconds after being turned on
Hi..there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Nov 12, 2008 | Computers & Internet
Monitor cuts off
Hi...there,
In power saving mode to preventing futher damaged to the monitor. It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it... Happy Holidays!
Nov 11, 2008 | LG Flatron L1750S 17" LCD Monitor
Flickering
Hi...there,
It's seems you got a busted backlight inverter...
Oct 28, 2008 | X2Gen MG19MY 19" LCD Monitor
GATEWAY LCD MONITOR FPD1530. UNIT SHUTS OFF IN ONE SECOND WHEN TURNED ON, EVEN WITH XP SOFTWARE TURNED ON.
Hi...there,
It's seems your backlight inverter are busted... need to replaced a new one or repaired it.
Aug 21, 2008 | Gateway FPD2275W LCD Monitor
Dell Dimension 4600 PC Desktop Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
