Question about Poulan 25CC Gas BlowerVac
How to set the ign. modualer on leaf blower - Poulan 25CC Gas BlowerVac
    President:
  • Poulan Master
  • 1,545 Answers
You have to set an "air-gap" on the ignition module between the legs of it and the magnets in the flywheel. Use a standard size business card as your "feeler gauge." Fold it in two. Place it in between the legs of the module and the flywheel. Turn the flywheel until the magnets line up with the coil legs and let the magnets draw the module into it. Tighten the hold down screws. Remove the business card. Your "air-gap" is now set at approximately .010" Closer is better, wider is not.
Posted on May 22, 2011
Not getting spark troy bilt snow blower model 7524
1st disconnect the auger /drive safety kill switch wire , see if it starts ? no? then it's most likely a bad ign modual or ign coil yes? then look at auger/drive control handle , i bet the spring broke and its not moving all the way up to disengauge the auger or drive
reconnect safety wire before using machine
Feb 23, 2015 | Garden
Off and on switch is always open on craftsman blower
try it with the wire unplugged from the module maybe your kill switch and or wiring is shorted
Mar 23, 2012 | Craftsman Garden
Bignition modual gap spec
The gap is to be set at 0.10, usually a business card works well for this.
Have fun.
Nov 12, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Will not start, replaced fuel lines (1 was broken) and spark plug
does it even run at all for a short bit? If not pull the spark plug from the unit, place some part of the spark plug threads on the metal surround the spark plug hole in the engine, turn the unti manually with the pull cord/starter and see if you get spark, if no spark it could be the Ign. coil module, a bad spark plug wire, or a break in the wiring to the ign. coil module.
Jun 07, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
I need to replace the on/off switch on my WORX grass trimmer do you have a schematic?
usually one side of the switch to the ign. coil and the other to ground or earth. simple mate
Apr 02, 2010 | Worx All-In-One Blower/Vacuum/Mulcher
358.794920, 200mph, won't start, no fire to spark plug, craftsman leaf blower
if you have no fire to the plug of course you have replaced the plug but now find the kill switch wire disconect it then see if it fires if it doesnot fire it is the ign coil
Nov 04, 2009 | Garden
Barracuda leaf blower quits after getting hot
Hello:
This is Usually Caused by a Bad Ign Coil/Module.
Replace the Ign Coil/Module and the Problem should be Corrected unless the Rings are Worn Out.
Operate the Unit until it Quits and then Check for the Plug Firing.
If the Plug is Not Firing, then a New Ign Coil/Module is Required.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro "Toro" Super Blower/Vac
Not firing
check the kill switch and all your wiring make sure there are no shorts also are you sure the coil is gapped right?
May 01, 2009 | Homelite Consumer Products Backpack...
Poulan 25CC Gas BlowerVac Logo
937 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
