Question about Wahl Health & Beauty
Wahl Clipper PCMC power screw adjustment information. Pet grooming clipper. Found something under model 9281-500, which seems pretty close, since it indicated it was actually for a model mc. The manual does state how to adjust the power screw, but it indicates that it to compensate for low voltage. Since the voltage is 124VAC, this does not seem to be correct.
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
SOURCE: reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Posted on Mar 17, 2009
SOURCE: Need advice on how to sharpen Wahl animal clippers
try getting they sharpened but this time when you use them oil between the two blades before during and after use. oil will maintain the useful life of blades.
Posted on Sep 06, 2009
SOURCE: how to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Posted on Dec 04, 2009
SOURCE: WAHL model MC. Very loud (mechanical)
Should have a flat head screwdriver handy... on the side of the clipper there is a dial where you can insert the tip of the flat head.. Turn on the clippers and turn that knob with the screwdriver slowly till it hums nice and even..
Posted on Nov 17, 2010
Why won't blades stay aligned?
Ok either the 2 screws that hold the blade to the clipper are loose or the adjusting lever on the side could be loose please check both.
P.S you must align blade before you tighten the screws.
www.angliaclipperservices.com
Anglia Clipper Services professional dog grooming equipment
Aug 25, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Wahl trimmer instructions
RTM. Read the manual. If you need a manual, you can get on by Google, with your make and model and manual and you should get results. Or go to pet grooming school.
Aug 06, 2014 | Wahl Animal Clipper Pcmc-2 Dog Cat Horse...
How do you adjust the head to cut various thickness of your dogs hair?
RTM. Read the manual. You're probably not using the correct blade and size.
How to adjust Wahl Switchblade clipper. I had it serviced and when I got it back I have to push down hard to snap in blades
Not a clipper adjustment problem, Has the clipper had a new hinge fitted?
Once a blade has been successfully fitted to your clipper will it go back on easier? ( this is normal as the clipper will make the blade socket the right width?
You should only connect a blade whilst the clipper is running so that the lever can locate into the blade.
Repair Servicing
Jun 13, 2014 | Wahl Basic Dog Clipper
Replacement filter for KM2
Contact your nearest Wahl agency www.wahl.com
Oct 29, 2012 | Wahl Two Speed Dog Grooming Clippers Km2...
Needs screws for a Wahl 8786451A Arco SE Pet Clipper
I would take it to Home Depot or Ace Hardware and gently try to fit screws in until something fits easily. Then adjust up or down for the correct length. Should be pretty easy.
Hope this helps! Dont forget to rate!
Jun 26, 2012 | Wahl 8786451A Arco SE Pet Clipper
Health & Beauty Logo
538 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
