JVC AV-36D502. Our TV has been on the fritz. Sometimes when we try to turn it on the power light just blinks. We have figured out if we wait a minute we can unplug the TV plug it back in and then the TV will function normally. Although it does take the picture a little longer to come up. Still looks fine though. Any ideas what may be causing this?
  • 8,457 Answers
U have tools like a soldering iron,a roll of solders and know basic soldering work?Yes.Resolders the FBT-(the flyback transformer) the big black block of plastic with a red wire with a cap hook to the CRT-(tv tube).On the side wall of the FBT.Have a Horizontal transistor in it side wall.Resolders that "H" transistor too.Will solved this highvoltages problems,should be stable the highvoltages to the tv and tv will work right away.
Posted on May 21, 2011
Will not power up
does any power indicator that blinks or no power at all?.
Oct 27, 2012 | JVC AV-36D502 36" TV
JVC Model AV-36D502 Blinking power light on start-up
you probably have some sort of overheating or short on the internal board - is it still on warranty? if so they will fix at no charge - if not, a local repair shop should be able to correct the problem but it may cost as much as $150
Jan 26, 2008 | JVC AV-36D502 36" TV
Want to connect my JVC AV-36D502 to my lap top computer
hi hmwpeg
• you may need a PC to TV Converter
like one of these:
http://sewelldirect.com/pc-to-tv.asp
instruction is on the web page.
• to enable on your laptop, set your JVC TV as secondary monitor.
• use the Catalyst control panel.
hope these helps
thanks for choosing Fixya for assistance
Sep 05, 2012 | JVC AV-36D502 36" TV
JVC AV-36D502 36
Check and replace the chroma IC.
Aug 13, 2012 | JVC AV-36D502 36" TV
Hi there TV is a JVC AV-36F713. Turned TV on a few days ago and nothing. Red flashing light on bottom of TV. Looked it up and manual said needs repair etc. Any ideas? Thanks Tim Also...
Hello Jim O'Connell,
Welcome and thank you for using FixYa!
To answer your question: I would suggest having a television repair professional pull out the power supply board.
They will need to remove the board and check it for bad (cold) soldier joints, bad capacitors, and lastly, to use an Osilliscope to test the +5v and -5V transistors on the board. If they can't diagnose the board, they can use the part number to order and install a replacement for you. That should fix your issue.
Have a great day!
Oct 15, 2011 | JVC AV-36D502 36" TV
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Feb 28, 2009 | JVC AV-32230 32" TV
JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Dec 02, 2007 | JVC AV-36950 TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
