Question about ION Audio Vinyl Recording Turntable
There are about 6 secs of recording in thr Int flash which stops me recording anything. I cant delete it.
  • 670 Answers
Do you have everything configured correctly?
Posted on May 25, 2011
I need to delete a recording
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B
2. Select file.
3. Press ERASE once and DELETE will flash on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B).
3. In Stop mode, press FORWARD continuously until “ALL” appears on the display.
4. Press ERASE and “DELETE” will flash on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Aug 14, 2009 | RCA RP5010 Digital Voice Recorder
Cant delete recordings
YOU CAN DELETE YOUR RECORDINGS WHEN YOU CONNECT YOUR MP3 TO YOUR WHEN THE OPTIONS LIKE SONGS,VIDEO OR VOICE COMES CLICK ON VOICE WHICH HAS UR RECORDINGS N DELETE THEM. HOPE ITS HELPFUL.
Jun 22, 2009 | Philips SA3025/37 Flash MP3 Player
Cant delete folders
1.push menu
2.select folder
3.select file
4.press erase once and "delete" will blink on screen
5.press and hold erase to confirm deleting (or press stop to cancel)
Erase All Folders
1.select folder
2.press erase once and "delete" will blink on screen
3.press and hold record for 2 secs.(Folder/All/Delete will flash at the same time)
4.press and hold erase for 2 secs. again to confirm delete
If you want to erase all the files in a particular folder will leaving other folders files intact.
1.select folder
2.press forward repeatedly until "All" appears on screen
3.press erase-"Delete" will blink on screen
4.Press and hold erase for 2 secs. and all files in that folder will be deleted
good luck
Apr 08, 2009 | RCA RP5012 Digital Voice Recorder
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Cannot figure out the command to delete
Try this.... hit erase on the one you want to delete, it will flash delete then the number of the one u should be deleting... now hold erase and it should be deleted
Apr 04, 2009 | RCA RP5010 Digital Voice Recorder
Cant get the songs to play over 10 seconds now what do I do
You probably have the setting on INT (Intro), that means the songs will only play for 10 secs (a sample) and continue throughout the whole list until the user stops it by pressing the INT button. If it still is acting funny, feel free to email more details.
Jan 14, 2009 | Naxa Electronics NX-671 Car CD/ MP3 Player
I cant delete a mic recording!
Tell me what you normally do first to try to delete it.
I'll see if I can help.
-AJ
Nov 23, 2008 | Philips GOGEAR SA6045 MP3 Player
Student library record
Import java.awt;
Import java.applet;
class Book extends Applet
{ String book name="Handbook";
int Book no=50;
int d.o.s=” ”;}
Type ur required body content here.
public static void main(String args[])
/*<applet code=”book” height=500 width=500 ></applet>
this appears to go beyond the scope of troubleshooting
Sep 27, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Rca rp5011a
Regarding RCA RP5011A
Turn on = Play + Menu (at the same time)
Turn off = Stop (will revert to just clock)
Selecting folders or changing options = Turn on then press menu to move through options and use the forward and backward buttons to change within options
Deleting a file within a folder = Select the folder through menu options (A or B) then exit menu (cycle through all options or press stop once while in menu) then press the forward key to cycle through files within folders (1 or 2) then press delete once to display "Del" next to file then press delete a second time to delete file.
Take batteries out to quickly reset recorder (will not lose saved files)
Jun 06, 2008 | RCA RP5011 Digital Voice Recorder
My recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
Feb 23, 2008 | RCA RP5030 Digital Voice Recorder
ION Audio Vinyl Recording Turntable Logo
76 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
