Question about Garden
We have an above ground level mounted pond with fountain which has a high (ish) central fountain above the pond and 4 sprinkler side fountains around the pond. we've replaced the previous pump by 3300 pump. Side sprinklers working ok but cannot get the central fountain to work. Fully checked pipe, nozzle etc - no blockages or kinks. Doesn't appear to have enough pressure to pump water upwards and outwards (originially installed a 1300 replacement pump and the 3300 is generating no stronger pressure in sprinklers, and no difference in central fountain i.e. no water coming up and out). We are completely at a loss as to what the problem is. Our electrician is helping and is demented at this stage! Please help!!
  • 776 Answers
Sounds like this is an issue of gravity allowing the lower level fountains to take all the water from the central (higher) fountain.
The pump needs to either be much stronger OR you will need to restrict the flow out of the lower fountains until the upper fountain starts to work OR reduce the number of lower fountains (this is just another way of restricting the flow out of the lower fountains).
I don't have details of your pump and fountain models but you won't get water up to the higher fountain if it can flow out of the lower fountains faster than you can pump it.
Good luck.
-Mark
Posted on May 21, 2011
How to install a sprinkler system ?
Sprinklers installation, especially pop up sprinkler installation is not simple generally.I tried installing it in agricultural land as per the advice of my friend.He also assisted me.But afterwards i had to call a professional to complete the installation.But i think for a garden we can do the installation our own.
Dec 19, 2013 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Sprinkler pump will not turn off when timer is turned to off new timer, new relay
go back to the drawing board re read instuctions,or go to there web site a simple fix im sure.
Aug 12, 2012 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Water is coming out between motor and pump housing
The pump seal needs to be replaced...it is a common part to find. If you need help in getting one please post the pump model and serial number.
John
Jun 28, 2011 | Flotec 1 - 1/2 Sprinkler Pump Composite...
How high does this pump example high high can fountain top be if pump is at bottom?
From the photo on the box, it looks like it will through a nice stream 4 to 6' high.
No details available though. Make sure the outlet of the pump is right at the water surface. You will need some rocks, bricks or a hidden floating platform to make it the right level.
If it is below water level, the fountain will be much smaller (may lose half of height for every inch below surface. 1" = 3 feet stream, 2" = 18 inch stream, ...
May 06, 2011 | Pontec Submersible Fountain Pump Sp 70g
Waterway hi flo above ground pump hums when turned on where is the starter capacitor did not see it where they normally are?
If not on top of the motor it could be in the back mounted to the end bell. Many motors now don't have a start cap but are wired to get this done. Sorry to say but a lot of motors are ment to be throw aways nowadays.
Apr 30, 2010 | Waterway Above Ground Hi Flo Pump
Flotec pump electrical problem
Not in the pump ... Check the start capicitor.
Mar 28, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
How do I remove the impeller from my Flotec pump?
I called Flotec and they provided perfect instruction. Opportunity solved.
Dec 07, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Sprinkler pump quits after 30 seconds?
call the company you purchased it through...that would be a warranty issue...sounds like it is overheating.
Jun 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Need to replace impeler on flotec pump
Contact flotec directly for impeller tollfree 1-800-365-6832
or they may have been acquired by Pentair so try
PENTAIR WATER
STA-RITE INDUSTRIES
200 Tate Street
Union City, TN 36261-024
(800)-800-468-7867
(FAX)-800-390-53
Feb 19, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
