Question about Apple Computers & Internet
Apple iMac CD
My Apple iMac ejects blank CD's as soon as they are put into the slot, no icon appears on the desktop.
  • blcjec9 Aug 15, 2008
    Yes. I think you may be right about the hard drive, the iMac is doing other strange things!
  • Apple Master
  • 1,800 Answers
Its might be a problem with the drive
Posted on Aug 15, 2008
Disc drive wont open. i pressed the eject button on my keyboard but it makes a clunk sounds but wont open.
This wil show you how to take it apart if that becomes necessary. But try this instead. First hold the eject button down for 5 seconds. I that fails look for a tiny hole near the disc slot. Use a straightened paper clip and push it in the hole firmly. This should eject the disc. Another option is to use firmware to eject the disc. Follow these directions: To eject a disc with Open Firmware commands, follow these steps:
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
  8. Your computer should now start up normally.
  9. Instructions curtorsey eh.mac.ca
Aug 16, 2010 | Apple iMac G4 Desktop
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
Sd card in cd slot of imac desktop
Use a large paper clip and fold it shaped. Gently insert it into the cd slot and drag the card out. My kid has done it twice so far. Make sure the power is off and if the clip hangs, don't pull.
Feb 18, 2010 | Apple iMac 20" Desktop
The container that hold my dvd disk wont come out when I press the open button on my apple computer?
It may be stuck so what you can try are one of these options:
Option# 1
* Shutdown your iMac G4
* Before you turn on your iMac, hold down your mouse button(s).
* Turn your iMac on still holding the mouse button(s) down.
* You will need to keep holding, until your disc ejects as your iMac starts up. That should do it.
Option# 2
If it does not, try using the Terminal utility to attempt to eject the disc.
* Click anywhere on the blank space of your desktop
and then you should see Finder appear near the Apple menu icon located in the upper left corner of your screen.
* Now from the Finder menu, select Go > Utilities.
* Within the Utilities folder. locate the Terminal application and launch it.
* When the screen prompt appears, type:
drutil tray eject
Option# 3
If that does not work, you can also try ejecting the cd using Open Firmware:
* Restart your Mac and hold these keys:
* Hold Command, Option, O and F keys while booting up.
* Now type: eject cd
To exit the open firmware screen type: mac-boot
One of these 3 methods should eject your disc.
If not, you may have a genuinely stuck CD in your drive and may need to take your iMac in to your local Apple retail store Genius bar or local Apple-authorized service center to have it safely and correctly removed.
Honestly, however, I have this same type of iMacG4- you will probably have the cd out by Option # 2 :)
Regards,
-Mactechtrainer
Jan 04, 2010 | Apple iMac G4 Desktop
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Put cd into the imac. Its now tuck. It wont eject and it sounds like the machine is trying to inmport.eject it. no cd icon has appeared How do I get the cd out
Holding down the F12 key for a few seconds will eject the cd on most macs.
Please let us know if this resolves yor problem. Thank you.
Sep 16, 2009 | Apple iMac 20" Desktop
IMac disk drive ejects audio cds
1) Restart the computer and try again. If that fails, 2) Gently blow canned air into your CD drive slot. If that fails, 3) Bring the unit in for a drive replacement.
Aug 25, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
CD/DVD Drive Doesn't work
Hi, Sorry to hear you are having problems,
One final test to try before declaring the drive dead:
Insert a bootable installation CD or DVD and restart right away. If the system ejects the disk, simply re-insert it as soon as possible after you hear the start up sound and then, immediately press the ( C ) button on your keyboard forcing the Mac to boot from the cd....
If your Mac boots, then the drive is OK it's your system that has a problem.
If the disk is ejected again, then you can declare the drive dead. It is a relatively inexpensive repair and if your Mac is still under warranty, then apple will take care of this no charge.
Good luck
Mar 21, 2009 | Apple iMac G5 Desktop
Computers & Internet Logo
197 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
