-having tuned in the stations how do i lock them in so they remain if I change channel. My remote control is quite old and the writing has rubbed away so i'm not sure which button has this function
    Scholar:
  • 106 Answers
Go through the menu, into the channel settings, there should be an option there. then just use the OK button on your remote.
Posted on May 21, 2011
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
Channel lock is stuck on
May 28, 2011 | Televison & Video
My tv model #27F500T is changing stations all by it self
the stations are changing by itself on your TV because the channel button on the TV is partially stuck in, that is why it keeps changing all by itself. This same thing may also happen to the remote control of the TV if the channel button of the remote stuck in and pointed at the TV.
Use your finger to rub the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Yours sincerely.
Elect_Comp
May 26, 2011 | Televison & Video
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
I have just purchased two srp2003/27 remote controls..i cannot enter set up mode because neither one of my tv's has a channel 1....the lowest one goes is 3 and the other 2..what can i do?
All TV sets go as low as channel 1. Its just that your tv has been preset to skip certain channels because no station was stored on them. All you have to do is go to the unit and manually change the stations with the program button.
If on the other hand this does not work try going through the menu button like you want to tune a new station and after tuning a station select it to be saved in position 1 Then you can acces channel 1.
Hope this solution has been helpful?
Sep 23, 2010 | Televison & Video
Just downgraded to basic cable. I have an older rear projection 56" sony(720p). My remote will only change channels with the digital pad. The channel +/- won't change the actual channel. If I hit the up or...
RE-TUNE UR TELEVISION TO FACTORY SETTING......U WILL FIND THIS UNDER MENU ON UR REMOTE CONTROL.....AFTER U HAVE DONE THIS U HAVE TO REINSTALL.(RE-TUNE UR TELEVISION STATIONS) U WILL FIND INSTRUCTION HOW TO DO THIS IN UR MANUEL
Nov 28, 2009 | Sony 42XBR900 Television
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Channel keeps changing
it seems to be continusly scanning channels and never ends
Jun 28, 2008 | RCA F32649 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
