My printer is not working as i have not printer installation
  • Anonymous Oct 28, 2008
    lost my disk to install printer
  • 88 Answers
Did you install printer driver
Posted on Aug 15, 2008
Printer stopped working
Please check it power cable or power board, if power section ok or working.
Then check you printer connection or not.
Check printer cartridge shot or not detect.
Check it printer head, if header not working then not print coming.
Check it your printer driver installed or not, if installed may be some problems then your printer not working. So old driver delete or new driver installed.
If other issue please tell you.
I hope solved your issues.
Thanks,
HP Printer Problems
Jun 18, 2014 | Brother HL-2040 Laser Printer
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
The printer is not printing
Dear emnyirenda, for various problems a printer can't print. See which one is yours. 1. You may not have installed your printer in your PC. If so, insert the CD provided with your printer in the CD Rom. CD will autoplay. Choose the install or setup option than easy install option. Your printer will install and start to work. 2. If you have installed the printer but not print, you may not install it properly. Go to Add remove hardware in control panel. Uninstall your printer software from there. Restart your PC and after that install again as No.1 instruction. It will work. 3. If not print, change the USB port where you using the printer cable to another port. 4. If not change the printer cable which connect to the PC.
Hope above solutions can helpful to you.
Sep 02, 2011 | HP LASERJET P1005 Printer
I just recently purchased a new computer with Windows 7 and have been unable to get the machine to recognize the printer. Will this printer work with windows 7 machines
Go to Konica web site and see if they have install software for 7. Not all printers and less scanners work with 7. Many printers work poorly if installed plug and play. Better success with manufacturers install program and follow EXACTLY the install directions.
Oct 09, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Can't install a printer.
install chipset drivers for the system, check cable, if it is USB, check in the device manager, proper drivers instaled, confirm, then proceed for instalation of the printer, it will works
Mar 23, 2009 | Compaq Evo D310v PC Desktop
I cannot find a printer to work on Acer Aspire X3200 Vista
any printer will work in your PC...as long as your computer meet the minimum requirement for the printer u choose
before you install the driver..remove or Un install the other program and driver you installed earlier
and restart the PC
you must install the right driver...install the driver that compatible to your Operating System (Xp, Vista), when installing the printer select the right port where you connect your printer (USB, LPT).
they are some installation instruction that you need to install the Printer Driver and Utilities first...then connect the printer or Restart the PC and connect the printer....
goodluck
Mar 16, 2009 | Computers & Internet
How to install hp laserjet p1505n network printer in windows 98
I can not find a win 98 driver for your printer on the HP website. DO yu have the instalation disk that was writen for win 98? If not try installing the printer through  the control panel. Either printers/fax or through install new hardware.The first being the preference. Some of the win OSs have printr drivers already installed.
If this does not work out, then the printer has no drivr available for that version of windows and you ewither have to upgrade to Xp or use a different printer which has a driver for win 98.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us〈=en&product=3435671&
Jan 02, 2009 | Office Equipment & Supplies
Printer will not work with new computor
Be sure that your printer is compatible with your new computer
You have to install the printer on the new computer in order to get your printer working
Run the installation CD or download the printer program from the internet.
If you already have your printer installed and it is not working
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 06, 2008 | Computers & Internet
Laptop doesn't recognise printer
follow instructions below,
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Install printer drivers from CD or from download.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some peinter does not work on Vista
Sep 14, 2008 | Dell 725 InkJet Printer
k24674
jasbo
jasbo
