Xerox xc865 - follow up questions
You are not getting any transfer. There are two types of transfers:
1- Corona wire; a set of very thin wires (hair thin and usually gold) that sit exactly against the drum. they are eiher broken or the unit is shorting out
< Is this something I can repair / replace myself - what would the parts cost to do so? >
2- a black spongy roller, usually don't go bad may need some recalibration
other possibility is the Developper unit,
which may be going bad look at it does it have a coat of toner on it? if no and you can see the long roller (it should be a silver magnet roller) if you can see the silver then there is not enough toner on the roller, it should have a thin solid layer of toner all the way
< is the developer unit something I can replace myself? what would the part cost & do I need a repair manual & special tools to do the work? Would I be better off getting a new copier?>
  • Jim Bob Mar 17, 2009
    I have a xerox xc865 copier with a broken corona wire.
    I had the same problem. After reading this post I found I had a broken corona wire.Is there an easy fix for this? I haven't been able to find an exact replacement part. It looks like the wire can be replaced but can't find the specs for the the wire. Any help with this will be greatly appreciated.
    Problem Solver:
  • 8 Answers
This copier has a toner cartridge and drum cartridge. If you are getting a blank page either the paper is not getting charged my the corona wire (located in the bottom of this device), or the drum is not getting charged. A great way to check is to open the lid and make a copy. When the page is half way through, turn off the device. Open the copier, remove the toner cartridge first (hold a piece of paper under it to keep from having a mess) then remove the drum. Inspect the drum. If you have toner on it, there is nothing wrong with the drum, you have a dirty or broken corona wire. If there is nothing on the drum, you may have a dirty or broken charge wire on the drum. If the device has been sitting around a while, the drum could be damaged. Replacement drums are $150. Back to the corona wire if there was image on the drum. These copiers used to ship with a small green cleaning tool inside for the coronal wire which was positioned on the bottom (inside) the copier...going from memory here. This is a thin wire that stretches across, if it is intact, try cleaning it with the cleaning tool, or a cotton swab.
Posted on Aug 26, 2008
.my ir 5000 gets a photocopy with a white line and agrey one side by side accross the paper
This is usually a dirty or worn corona wire problem. There are three corona wire units in the copier, a charge unit, pre-transfer unit and a transfer/separation corona unit. You probably need new corona wires strung, or new units. You will probably have to contact an authorized Canon dealer for repairs and parts. This model is very old now, and discontinued/obsolete. Getting parts may be an issue.
Jan 27, 2017 | Canon imageRUNNER 5000 Copier
My canon ir5000 has a deletion in some papers White area accross the paper
This is usually a corona wire problem. There are three corona wire units in the copier. You probably need new corona wires strung, or units. You may get lucky though and just have a hung transfer/separation corona wire cleaner. This is visible if you slide out the transport unit by opening the front door and releasing the green handle, then sliding the drawer assembly out. Look for the unit with the 3 thin, hair thickness wires running front to rear in the silver cavity located just to the right of the black rubber wide transport belts. The unit will have a white plastic "bridge" on it. Look to see if there is an assembly that has cleaner pads on it stuck somewhere along the wires. If it is, be careful and slide the assembly all the way to the front of the corona unit. If there is a problem though, the next time it cleans the wires it will get stuck again. You will probably have to contact an authorized Canon dealer for repairs and parts. This model is very old now, and discontinued/obsolete. Getting parts may be an issue.
Jan 26, 2017 | Canon imageRUNNER 5000 Copier
How to clear a code
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
Apr 21, 2014 | Minolta EP4000/5000 CS/PRO Copier
Ep3000 how to clear a code co200
Sir/Mam
If available
Di470 error code c0210
Image Transfer/Paper Separator Corona charge leak detected and replace the
open front door pull main lever down and remove the small assy. with a small handel sticking out, replace the two very thin wires and the two end parts normally white try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
ask for corona wires and corona housing end parts worse cast the HV power supply went bad
Jan 26, 2014 | Konica Minolta Office Equipment & Supplies
I have replaced the toner cartridge on a Xerox XC 830 copier with several new cartridges. I still get light images and horizontal dark and light stripes where it should be a solid dark block.Drum was...
Have you attempted to print to the copier? Doing this completely bypasses the optics of the copier and therefore you are able to potentially narrow down the cause of the banding.
On cleaning optics: on the right hand side of the machine, near the top, or on the top, of the scan bed there should be two to four screws that hold a plastic cover in place. After removing the cover you should be able to gently lift the glass up and out of its housing. Using windex or any other sort of glass cleaner on the reflective mirrors will do the trick. However, this does not sound like an optics problem.
Have you inspected either the transfer belt, roller, or transfer corona wires? All of these parts can be accessed from the right side of the machine. Gently clean the thin wires with a rag and some sort of general cleaner.
-David.
Oct 30, 2010 | Xerox 8830 Copier
Brother not printing
Hi John, the machine keeps asking you to clean the corona wire because on start up or especialy when the machine readies it's self to start printing, it passes a voltage through the corona wire which helps the drum erase the charge on the organic photo compound the drum is covered in.
If the machine sees any problem with the transfer of this voltage it thinks there is a problem.
The corona wire can be cleaned by sliding the blue tab on the top of the drum from right to left a few times.
You should check to see if this wire is broken ..it a very thin wire about the thickness of a human hair, if the wire is not broken then try cleaning the thin metal grid below the corona wire with a cotton bud , being carefull not to break the wire.
If this doesnt work then it sounds like the high voltage connection on the drum is faulty, and you will need to purchase a new drum ( or take it back to the supplier and say it is faulty and you want it replaced).
You ould also clean the surface of the drum itself carefully with a soft DRY clean cloth.
The only other cause is the high voltage supply pcb is faulty. Which if the machine is out of warranty is prohibitavely expensive to repair.
Hope this helps
Mar 03, 2010 | Brother HL 2140 Laser Printer
How do i clean carona wire
For a photocopier to work, a field of positive charges must be generated on the surface of both the drum and the copy paper. These tasks are accomplished by the corona wires. These wires are subjected to a high voltage, which they subsequently transfer to the drum and paper in the form of static electricity.
Visit the following website and your question will be answered...
http://www.retrevo.com/r/23303dj198/180/Cleaning+the+corona+wire/
Nov 08, 2009 | Brother MFC 7840W Printer
I have a Konica 4145 copy machine with error code 60
There is arcing from the transfer corona, HV wires underneath the drum these thin wires provide a HV allowing transfer of the image from the drum to the paper, and allow seperation of the paper from the drum. (p/n 5400-2605)
Aug 19, 2009 | Konica Minolta Office Equipment & Supplies
XEROX XC865 - No image
which may be going bad look at it does it have a coat of toner on it? if no and you can see the long roller (it should be a silver magnet roller) if you can see the silver then there is not enough toner on the roller, it should have a thin solid layer of toner all the way xerox%2520xc810%2520drum%2520cartridge.gif
Aug 07, 2008 | Office Equipment & Supplies
296 people viewed this question
jasbo
jasbo
