Question about Bosch HBN 7022GB / 7062GB Electric Double Oven
I have a bosch HBN7050GB/1 double oven. It is about 8 years old and last year blew its main oven heating element. I replaced the element with a new version and this lasted me about 3 months before it blew in a similar location to the original. I managed to get the element replaced but the replacement has also blown in a similar location to both previous elements. My door appears to be sealed and the fan still runs. The oven is pretty clean and all element cover vents are clear. Please can you advise what I can check or do, or if it is possible I have been unlucky enough to recieve 2 dud elements? Please offer me advice on how best to deal with this oven. Thanks
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
SOURCE: Bosch fan oven not working
This does not mean your element is broken. Although it could be. Call Bosch and ask them if the unit has a pressure switch (you will need the model number). Pressure switches are more common on Gas ovens, but it might have one. If the pressure switch is not being activated by the fan, that could be the problem. It could be a contactor, it could be your power switch. It could be a break in the wiring. Or it could be your thermostat, or it could be the element. Service companies usually charge you for the cost of traveling to your place and around here hourly rates from $65-125 per hour for labor. It could take up to two hours to find out what the cause (or causes of the problem are) depending on how thorough they are. There could be a return trip charge as well if they need to order parts. And the cost of parts as well. you could be looking at anywhere from $300 to $1200 dollars depending on how many components might be damaged and the cost of the parts. If you want to save some money in the future, always check your fan blade to make sure it is free of debris (especially tin foil) and make sure the motor on the back of the oven has some clearance from the wall so it can cool itself.
Posted on Jun 17, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
  • 134 Answers
SOURCE: MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Posted on Feb 20, 2009
  • 27 Answers
its the element not the stat
Posted on Mar 10, 2009
Oven won't heat
hi, sounds like the heating element
Mar 07, 2010 | AEG U3100-4 Electric Double Oven
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Hi
Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
Bosch convection double oven,ovens won't heat,only broilers work
Thanks.
Dec 17, 2008 | Bosch Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Bosch HBN 7022GB / 7062GB Electric Double Oven Logo
144 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
