Question about GE Kitchen Ranges
My gas range model number JGS968SOH33SS will not heat. Thermastat stays at 100 degrees. The gas burners and broiler work. Repair man says it can be a problem in the control panel. Any other things that it could be?
  • GE Master
  • 2,605 Answers
Hello, welcome to FixYa.
Based on your description, I`d suggest the hot surface ignitor for the bake burner is likely the problem. Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined.
It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
since your boiler has the same ignitor ( some do some don't, only a model number would confirm or dismiss this...thankfully you provided yours ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case.
You can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake & broil ignitor.
I would still double check with your model number with the part`s professional`s.
Hope that help`s. It is very unlikely to be the control panel/timer contrary to what your repairman has said...in my opinion. Let me know if I can assist you further and good luck.
Thank`s for visiting "fixya" for your repair needs.
Regards,
Macmarkus :)
Posted on May 21, 2011
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
JennAir Gas Oven won't heat up, it stays at and displays 100 degrees, but it isn't warm. Moedel JGR8885RDP. The gas range works fine and so does the broiler. No error codes pop up on the display.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 24, 2011 | Jenn-Air JGR8885RDP Gas Range
Oven burner does not light. broiler burner and all other stove burners are good.
heatman101
Nov 09, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
heatman101
Oct 13, 2010 | Maytag Ovens
My jgs968 oven won't light. It stays at 100. The burners and broiler work
heatman101
m,b,m
Jun 24, 2010 | GE Profile JGS968 Gas Kitchen Range
Maytag Gas Range broiler burner not working
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
